Backup Camera DIY
#125
Professional Newbie
Nice, I'm definitely going to do this project next if I'm not entirely broke from my audio install!!
Has anybody heard from Dom lately? I need to get a NavitoTV module or whatever they call them.
#129
are the molex pins the best pins to use? i feel like part of my problem is that the pins aren't making a good connection with the dvd player socket. are there any other type of pins i can use? or does anyone know the exact pins that are supposed to work with this socket?
#130
Instead of the using a female RCA end and wiring it up, couldn't I just use this http://www.radioshack.com/product/in...tId=2103848&cp from Radio Shack to connect to the 7 pin terminal? Forget that it's a male RCA. It won't matter for what I'm doing.
#131
私はより良い
hehe this is totally off topic, but this:
i found out that this is a glitch..
if you try pressing dual without auto on... it wont turn on
however if you press ( in succssesion) auto - dual - windsheild defroster- windshield defroster... the dual light will turn back on without auto being activated
however.. this is a mistake... because dual being on without auto means absolutly nothing... the climate control is off...
annnnnnnnnnnnnnnnddd... back ON TOPIC:
i got my camera today, but Im waiting for finals to finish before i start installing
#132
#133
if you have Dom's unit and are using both inputs 1 and 2 on it, can you still do the DIY and make a connector? Basically i have a dvd on input 1, am putting a ipod video into input 2 (with a switch, not connected to reverse 12v), and do the DIY for backup cam, but not sure if this will work...
#136
+12v, yeah. But, you can't use a 3-way rocker for the 2 sources, since the switch (red/black) does not use 12v. Make sure you measure it with a DMM and give it the right signal or you could hurt the Dom's.
#138
#139
私はより良い
FINALS ARE OVER!!1
THANK GOD!!
I'LL be installing the camera on sunday... if it stops raining (please god?)
and I'll stop by radio shack tonight and see if I can find the connecters and other pieces...
if I can't find them at radio shack.. is there anywhere else I can get one (xcept for ebay)
THANK GOD!!
#140
私はより良い
well.. f*ck it...
went to 2 different radio shacks and none of them had a clue about what I was talking about...
and I cant find this damn piece online too....
i'm about to give up... so someone better help me find this piece
#141
Originally Posted by cybereclipse
well.. f*ck it...
#143
im not talkin about the rca connector... im talking about the molex 7 pin plug..
wth am i supposed to find this?
#144
alright so I need some help from the A/V gurus here. Does anyone have any clue as to why my camera would be going in and out? It will work for a few seconds and the video will be clear as day...and then it will go back to a black screen. It has also worked for a few minutes, and then it does the same thing....what do I need to fix/adjust? I finally have some time to devote to this project this weekend so all help is appreciated!
#145
I can't find my garage
if i want to add a 12v switch for a dvd or w.e which pin would i plug it into this molex? i would remove the jumper too right? because i dont need a back up cam
#151
How many of you backup cam DIYers take off the camera before going through a car wash? Even at my local car wash (no brushes...all hands/towels) I can imagine the water spraying and soap would affect the cam.
#152
Bueller? Also, do you guys screw it into the trunk lid, or do you just attach it w/double sided tape?
#154
Originally Posted by mltk53
many will not recommend screwing it because it can cause rust. so your best bet is a super duper crazy strong tape
I guess I could find stainless steel screws. But I'm sure non-permanent attachment is for the best. I could always sell the camera when I sell the car.
#155
So I got the wendy's cam in the mail today, and I want to test it out before I go to work on a navi adapter. Can I just hook the black wire to the negative terminal of a 9volt battery, and the red positive wire to the positive terminal of the battery? Then I could just plug the rca cable into my Tv. Or do I need 12volt power only. If so, how can I test out the camera w/out connecting it to my car's electrical system?
#157
#158
私はより良い
well... im bringing this thread back to life temporarily..
i still have the camera ( been sitting in my cabinet for a couple months)... and i still need that darned molex connector
can anyone tell me where i can buy one?? (not online) it seems that Radioshack has no clue what I'm talking about
#160
I bought this 3m trim molding tape to hold my camera to the trunk lid:
I looks strong, but it doesn't seem to hold as super-strong as double sided foam tape. Do you guys know if this stuff is designed to hold up to vibrations/water? I thought it would be stronger since it's designed for automotive trim. Anyone think this will work alright for my camera? Do you recommend something else?
