Add-A-Circuit Tip
Make MyTL Great Again
Add-A-Circuit Tip
Don't be like me. Don't waste an hour wondering why you aren't getting any power on your new wire.
When you use add-a-circuit, make sure you have a fuse in both spots of the unit, otherwise you will get no power on the wire for the new device.
Yesterday I was trying to install my Escort Passport 8500 x50. I installed the add-a-circuit device into #29 on the fuse box (the IGN OP1 - free for owner use). I only put a fuse in the spot for the new line, since there is nothing hooked up to that spot normally, there should be no need for a fuse in the other spot, cause it's not being used for the car. Well it looks like you need a fuse in that other spot, which acts like a pass-through, otherwise there will be no power on the new line. Would have been nice if the instructions/box mentioned that!
Originally Posted by btvudoo
how does it look like?
The link Canadian Mike posted shows the unit in action, and here's what the instructions and (opened) box look like:
Cost is about 10 bucks
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
