Headlight bulb change gone wrong
Old 05-25-2016, 06:21 AM
5th Gear
romac's Avatar
I broke the clip holding the bulb in place. The rubber gasket was a bit baked in place and I tugged apparently a little too much, broken plastic wire clip holder... bam. Now what? Any ideas? btw, zxe bulbs went simultaneously, one year.
Old 05-25-2016, 09:05 AM
Received 8,585 Likes on 6,631 Posts
buy a new one
Old 05-28-2016, 10:12 AM
5th Gear
romac's Avatar
brilliant, thanks.
Old 05-29-2016, 10:39 PM
Acura Fanboy
knavekid's Avatar
If you can find the broken piece, you should be able to JB Weld it back on. Perhaps you can rig up another way to fix it. Either way requires removal of the bumper cover in order to remove the headlight assembly.
Old 06-01-2016, 02:35 PM
5th Gear
romac's Avatar
Thanks, the tiny plastic curl that holds the clip has broken. I just used the rubber collar cover to hold the bulb in place. It will probably shake at speed over bumps but oh well. It is functional so far.
I CU2
02-12-2016 11:45 PM
Skirmich
1/2G MDX (2001-2013)
28
02-08-2016 03:38 PM
Quick Reply: Headlight bulb change gone wrong
