Motor Assembly, Drive Air Mix
Old 11-27-2018, 11:39 AM
DMZ
Head a da Family
DMZ's Avatar
Acura part # 79166-SEP-A02. That little motor that controls opening and closing of the heater valve via a little cable.
All the on-line dealers want around $250!
Any suggestions gang?
Old 11-27-2018, 11:50 AM
Received 16,260 Likes on 11,971 Posts
When I tried to buy in 2015, discontinued or no ETA available... i ended up just grabbing one from the junk yard....only 4 years later it has failed again... this time; instead of replacing, I'll try to clean the contacts, as that's what makes it stop working in the first place.
Old 11-27-2018, 12:09 PM
Received 8,584 Likes on 6,630 Posts
junkyard
Old 11-27-2018, 01:13 PM
DMZ
Head a da Family
DMZ's Avatar
junkyard
My thoughts exactly!
Tanksh!
Old 11-27-2018, 09:00 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Are you sure it's the motor and not the valve itself or the cable?
Old 11-28-2018, 01:26 PM
DMZ
Head a da Family
DMZ's Avatar
Which contacts specifically?
Old 11-28-2018, 01:47 PM
redbeard1's Avatar
I've circled the areas to clean.
This DIY is for 2g but the motor is pretty similar to 3g.
https://acurazine.com/forums/second-...repair-848488/
Old 11-28-2018, 03:21 PM
DMZ
Head a da Family
DMZ's Avatar
Certified by Paul, our star master mechanic here in Northern NJ
Old 12-06-2018, 06:13 PM
DMZ
Head a da Family
DMZ's Avatar
Paul, our star master mechanic in Northern NJ to the rescue! He took it apart, cleaned the contacts as described above, and WOLA! The heat works perfectly again!
Anyone in the NYC/NJ area are who needs work done on a Honda or Acura should call him, 201-562-8576. Tell him Tony Soprano shent ya!
Skirmich
11-06-2023 07:55 PM
SweetBabboo9713
06-15-2014 04:32 PM
chris03tl
03-27-2012 07:22 PM
9932
08-24-2009 12:39 PM
tmcnamee
10-26-2006 06:05 PM
Quick Reply: Motor Assembly, Drive Air Mix
