Check engine light....??
Old 02-05-2011, 12:11 AM
Black Dameon TLS's Avatar
Exclamation Check engine light....??
Ok so today I opened my intake filter box to check my filter out and seen that it needed to be changed. The bottom was nasty black and looked horrible. Anyway I just purchased a K&N filter as my replacement because it's tradition and I like K&N (all my cars have used K&N). In order for me to get the box for the filter open I had to remove a few things like the throttle sensor and stuff. After installing the K&N filter the car started up fine but now I have a check engine light on. The comp says that my acceleration will be less and throttle reaponce will be delayed. What in the world happened? Has anyone had this problem before after buying a K&N filter?
Old 02-05-2011, 01:20 AM
NAiL05's Avatar
You sure you hooked everything back up?
Old 02-05-2011, 01:24 AM
TL-S
quanaman's Avatar
Make sure you bolted everything back up tightly enough and hooked it all back up correctly...then reset the code and see if it comes back.
does it sound different to you at all? like maybe there is an air leak somewhere or something? That should give you a hint of where there is a leak; if there is one.
good luck!
Old 02-05-2011, 07:06 AM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
My guess is you forgot to reconnect the MAP sensor connector (A):
Old 02-05-2011, 08:16 AM
Well I think I connected Everything back correctly I mean I didn't remove the TB. all I disconnected was (A) the map sensor and that pipe hose to the right of the map sensor in your pic. I also accidentally started the car when I had the filter off and out....it sounded like it was going to die.....did I do something to mess up the comp? I also got this message about my stability control.
Old 02-05-2011, 09:01 AM
NAiL05's Avatar
No you just need to reset the ECU.
Yikes
05-03-2021 04:29 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
Quick Reply: Check engine light....??
