RDX Brake Covers installed!
Old 01-17-2013, 08:09 PM
  #321
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Not sure-you might check the 4G TL Community to see if anyone has them.
04WDPSeDaN (01-18-2013)
Old 01-18-2013, 07:23 AM
  #322
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Received 2,563 Likes on 1,317 Posts
They may not fit, however the tab can be bent if need be to fit on the caliper. As far as the rears go, i'm pretty sure they won't fit since the calipers are bigger and these just about fit on ours.. Don't forget these are made for the 2013 RDX front calipers so they should fit on the front calipers.
Old 01-26-2013, 01:07 AM
  #323
Carson-TL's Avatar
Man the covers look awesome, but I would only get them if they came in blue.
Old 01-26-2013, 06:20 AM
  #324
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
You can repaint them, other have done that already.
Old 01-26-2013, 02:21 PM
  #325
Carson-TL's Avatar
What I would want is the entire cover painted blue and the words white...But I don't know how to do that other than spend 6 hours perfectly laying tape of the words. How did other people do it?
Old 01-26-2013, 04:12 PM
  #326
Carson-TL's Avatar
*over
Old 01-26-2013, 04:50 PM
  #327
Type Sour
THEReeM718's Avatar
Buy Acura decals on eBay.
Old 01-26-2013, 05:04 PM
  #328
Carson-TL's Avatar
That.....is an excellent idea!
Old 01-27-2013, 08:41 PM
  #329
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Got mine on the front today! They look great!!
Old 01-27-2013, 08:47 PM
  #330
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
for Harbor Freight Jack....I just picked one up earlier today
the caliper looks great Austin....your car has come a long way....
Undying Dreams (01-27-2013)
Old 01-27-2013, 08:55 PM
  #331
Not bad Austin!
Old 01-27-2013, 08:56 PM
  #332
swoosh's Avatar
^^^ Steven stop following me
Old 01-27-2013, 09:26 PM
  #333
Thanks guys!
Anil, beware. That jack weighs. A LOT.
swoosh (01-27-2013)
Old 01-27-2013, 09:53 PM
  #334
swoosh's Avatar
^^^Thanks for the heads up buddy....i realized that when picking it up today
I wanted the Aluminium jack but Matt told me to get a different one as the Aluminium jack doesnt raise it much....(only 14-15") where as this one goes all the way upto 20"....
my old jack had become "self lowering" /hijack
Caliper cover look great Austin...
Old 02-28-2013, 09:45 PM
  #335
slogsr's Avatar
Can anyone tell me if these are metal or plastic? I am powder coating my front calipers and would like to order these if they are metal to powder coat to match.
Old 02-28-2013, 10:25 PM
  #336
I Like turtles
GeeteeDan's Avatar
Swoosh, what model did you pick up from harbor freight? I have seen a low profile jack online and now that my regular Walmart jack won't fit under the side, I have a reason to head over and get a new low profile jack.
Old 02-28-2013, 11:17 PM
  #337
swoosh's Avatar
Dan,
I ended up getting this for $60 - 2.75" low and lifts upto 20"
http://www.harborfreight.com/automot...eel-68049.html
I really wanted this one but didnt wanna spend $140 on it...2.5" low and goes upto 23.75"
http://www.harborfreight.com/automot...uty-68050.html
the above jacks are really heavy but lift range is good....the following jacks are lighter and they dont raise the car as much and are on the higher $$$ side
like this one is 3.25" low and lifts upto 18.5"
http://www.harborfreight.com/automot...ons-68051.html
this one is cheap but 3.33" low and goes upto ONLY 14.75" high
http://www.harborfreight.com/automot...html-7814.html
GeeteeDan (02-28-2013)
Old 03-01-2013, 06:30 AM
  #338
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Covers are metal.
slogsr (03-01-2013)
Old 03-01-2013, 07:32 AM
  #339
slogsr's Avatar
Originally Posted by 04WDPSeDaN
Covers are metal.
Thank you sir, just ordered mine with that answer.
Old 03-01-2013, 07:48 AM
  #340
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
This is late in the game but I wanted to say...
I personally feel like the only area that gets RTV that is really holding these covers on IS the long actual caliper part... And I wouldn't have felt safe not RTVing it to that. It's the only place with solid contact that has "no pressure".
So what if you gotta rip these off, shave the old rtv off, and remount every XX,XXX miles for pads...
Old 03-01-2013, 09:14 AM
  #341
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
You RTV only on the caliper bracket. I've put on roughly 2,000 miles and already did my brakes (Pads w/rotors) None of which had any issues with the cover being on. Others have done brakes after the covers were installed and didn't need to remove them also. RTV allows flexing, is great for all sorts of temps and last's almost forever. If you follow my instructions for installing them you will not have a problem. Think about how other caliper covers (Plastic ones) are installed? Those fancy brembo fakes.. are installed the same way, with glue. In this case RTV is much better than the crap most companies supply to install them.
Now all this applying on the caliper bracket was for the rears, on the fronts you can install them to the caliper themselves. You will have more area to support and again, it's not needed to remove them for doing a brake job.
Bottom line is: They look great, they are metal (painted, finished) and aren't a safety hazard.
The following 2 users liked this post by 04WDPSeDaN:
BreezyTL (03-01-2013), wusty23jd (08-14-2018)
Old 03-04-2013, 03:23 PM
  #342
BreezyTL's Avatar
$28.13 each from a local Acura Stealership... might have to wait til I find a better deal...
Old 03-04-2013, 04:06 PM
  #343
teeeejaay's Avatar
Hey sorry guys I been trying to read through all the threads about the RDX brake covers, I read they fit the rear brakes on base and tls
What about the fronts? I have a base 04 so what do people install on the fronts? The same ones as the rears? Just looking for help because my car show is the end of this month so im trying to order the parts asap.
Thank you!
Old 03-04-2013, 08:05 PM
  #344
BreezyTL's Avatar
Thank you!
you put the same ones as the rears on the front. no need to use the RTV. just have to RTV the rears because of the smaller caliper. Good luck finding a place that has 4 in stock! my local dealer only had 1 and there was 1 in california (makes 2 total...) still need 2 more, and for almost $30 a pop Ill look elsewhere for them!!
Old 03-04-2013, 08:08 PM
  #345
teeeejaay's Avatar
Thank you!!!
I bought 4 earlier today just to take a chance, but glad i needed 4.
I didn't go down to my local dealer since hawaii only has 1 and they suck super bad in my book.
I bought them from curry acura for $52 for all 4 thats to hawaii, idk what the price diff for you guys.
  #346
Type Sour
THEReeM718's Avatar
^^ I have one for sale in the black market. Pm me
Old 03-04-2013, 08:09 PM
  #347
teeeejaay's Avatar
Will that get in the way of my future brake pad changes etc...? the RTV on the rears
Old 03-04-2013, 08:20 PM
  #348
BreezyTL's Avatar
Originally Posted by wilzrsx
No it would not. I have the covers installed and had to swap out defective pads for new ones and had no issues.
has stated no issues with brake pad changes. i do not know personally as i do not have them, but from that statment i quoted, id say we will be safe. one way to find out right!!!
Old 03-04-2013, 08:22 PM
  #349
BreezyTL's Avatar
trying to find 4 all together instead of getting 1 by 1... if i can't find 4 and you still have it ill send you a PM. i see you are asking for $15 how much would shipping be? (ballpark)
Old 03-04-2013, 08:34 PM
  #350
Type Sour
THEReeM718's Avatar
^^ PMed you
Old 03-04-2013, 09:27 PM
  #351
TLX-S
wilztlxs's Avatar
Thank you!
for the rears, using RTV, the covers are mounted to the caliper bracket.
for the fronts, using RTV, the covers are mounted on the caliper itself.
the covers are not in the way when you need to change the brake pads. i had to change a full set of pads with the covers and had no issues.
BreezyTL (03-04-2013)
Old 03-05-2013, 10:39 PM
  #352
2005 TL SSM
PWNage133's Avatar
Great way to clean up the brakes for 5AT guys! Now I just need to track down some parts!
Old 03-06-2013, 07:45 AM
  #353
zachlone's Avatar
I was scared at first that id have to take off the covers everytime I needed to change pads, thanks for clearing it up and proving they dont have to be removed.
Old 03-13-2013, 01:58 PM
  #354
US Navy Seabees
Ruby's Avatar
So what happens when/if the glue breaks off and now you have a caliper cover flying off inside your wheel? It could damage brake lines, etc. Anyone think of this?
Old 03-13-2013, 02:15 PM
  #355
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
That, would suck.
Old 03-13-2013, 02:19 PM
  #356
maharajamd's Avatar
It would bounce on the inside of the wheel for a second then fly out. I don't really see it being an issue.
With how I RTVed mine, that shit isn't going anywhere.
Old 03-17-2013, 10:05 AM
  #357
jon2000's Avatar
Great thread OP! Thanks. I just picked up two of these last week for my rears at a local dealership in Canada for $3.90 each. I'll get these installed when I switch to my summer wheels.
Jon
Old 03-17-2013, 04:07 PM
  #358
Titanium2k2's Avatar
Oh great, here I go spending more money on the TL. At least this mod is nice and cheap and looks great!
Old 03-17-2013, 07:31 PM
  #359
3 2 GONE
ATLS_666's Avatar
Is the caliper bracket made of cast iron?
Reason: Self tapping into cast iron will most likely crack it. I want to do this mod but I want the added security of self tapping screws.
Old 03-17-2013, 08:18 PM
  #360
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
^the RTV is strong enough. If you need added protection you can use JB Weld Epoxy. Personally I wouldn't drill into the caliper
Quick Reply: RDX Brake Covers installed!
