New ECU preview
Old 01-31-2011, 04:19 PM
KN_TL's Avatar
New ECU preview
I've gotten some information on the upcoming ECU product.
It is based on the MegaSquirt3 ECU modified to interface with the 3G TL ECU.
MS3 info is here http://www.ms3efi.com/product.html
Here are some things you can control (Items are hyperlinked)
This also means that the tuning can be performed using MS compatible software. The current software being used is TunerStudio. It can be downloaded for free and also has a register option. More information is available here:
http://www.efianalytics.com/TunerStudio/
One HUGE feature is VE Analyze Live. Read about it here:
http://www.efianalytics.com/TunerStudio/#veAnalyze
Some questions and answers so far:
Q. Will the stock ECU be retained ?
A. Yes, this insures that all factory features are not lost
Q. If the factory ECU is still in place, are you simply intercepting the signals?
A. No, the FACTORY ECU has no control over engine parameters.
Q. Will this be a Plug and Play install or do I need to custom wire?
A. This solution will be Plug and Play with a pre-wired harness included.
Q. Are Base Maps Included?
A. Base maps will be available based on the application.
Q. What is VE Analyzer ?
A. A tuning tool that tunes while you drive! See http://www.efianalytics.com/TunerStudio/#veAnalyze for more information.
Q. Is drive by wire retained?
A. Yes along with all other luxury features handled by the stock ECU.
More info, Email - tl20046speed@yahoo.com
Old 01-31-2011, 04:26 PM
Lazer187's Avatar
Sounds awesome and very helpful, but i dont know if this has to due with the ecu or not. I would like to see on the list:
Fuel cut off max speed removed (so its not governed), and seat belt chim disabled. does the ecu control those 2 points?
Old 01-31-2011, 04:29 PM
Comptechtl2367's Avatar
This sounds great! I would love to get my hands on one of these... any guess on price with harness yet?
Lazer: You can make the seatbelt chime go away by putting your seatbelt on! Easy fix! :-)
Old 01-31-2011, 04:30 PM
KN_TL's Avatar
This really is not to address those issues.
It is for the people who want full control over the engine tuning (turbo, supercharged, NOS, etc).
Old 01-31-2011, 04:38 PM
KN_TL's Avatar
I forgot that there is a short video.
Please ignore the fact that the tuner left the key in the ignition. Better videos to come:
http://s1193.photobucket.com/albums/...current=TL.mp4
Old 01-31-2011, 04:46 PM
18psi
libert69's Avatar
Yes it can do that
Old 01-31-2011, 04:53 PM
That looks bad ass! When this is released i need it!
Side Note: Is that your car KN_TL? Looks like the A-pillar gauges dont work and i like the placement of the wideband and true boost... just not that its drilled through the fold down cover!
Old 01-31-2011, 06:48 PM
04Tl
Yonkers914's Avatar
Nice job on the ECU amazing!!!
Old 01-31-2011, 07:07 PM
KN_TL's Avatar
No, this is Rodney's ride. I am trying to find out what pod that is and where he got it. Mine is drilled and mounted to the cover.
Old 01-31-2011, 07:24 PM
jnc2000's Avatar
This is HUGE! A big THANK YOU!
Old 01-31-2011, 07:27 PM
anx1300c's Avatar
Mad props, man!
Who's gonna be the N/A guinea pig to try this? I want to see what kind of gains can be made on a car with full bolt ons and P&P intake and runners by adding more fuel and timing. I think there's some power to be made in the 5k + rpm range.
Old 01-31-2011, 07:33 PM
spade0698's Avatar
I want this.....
Old 01-31-2011, 07:47 PM
B A N N E D
friesm2000's Avatar
why no 2g support , the AEM EMS is a joke personally, when trying to keep it interfacing with the the other modules in the car
Old 01-31-2011, 08:15 PM
KN_TL's Avatar
You're going to be hard pressed to find someone willing to pay over $1000 for limited gains.
Old 01-31-2011, 08:54 PM
bmeyer's Avatar
For those asking about price... the product has not been released yet so it may be subject to change. All I can say is to expect something in the neighborhood of an AEM EMS setup.
Old 01-31-2011, 10:49 PM
Inaccurate's Avatar
Wow. Simply amazing. This will allow the TL to be a true player in the tuner community.
With this, a high duration camshaft now becomes more feasible. With a long duration camshaft (at least 252 degrees at 0.050), the peak HP (more specifically, the shift point) can easily be 1000 RPM higher than oem. So if you are still shifting at the 7200 RPM oem limit, you are unable to reap the benefit from the big camshaft.
With this unit allowing the RPM limit to be raised to 8000+ (and stiffer valve springs), people can now pursue some old-fashion hotrodding (cams, ported intake). The only major piece missing is being able to change our axle ratio. J&R, any plans to offer axle gears?
Cool guy in the vid. Is that Rodney in the video?
Old 01-31-2011, 10:54 PM
siularbar's Avatar
Good shit! So, this thing completely eliminate the stock ECU, and able to tune closed loop?
Old 01-31-2011, 10:56 PM
TLdream's Avatar
Mad props, man!
I will have one. I will also provide back to back dyno results using a factory ecu, then using a tuned JandR stand alone.
People will jump on this after they what it is capeable of. The swap guys are goign to love it.
Not sure if i should say anything, but gears comeing sooner than later.
Old 01-31-2011, 10:58 PM
B A N N E D
friesm2000's Avatar
i think something along the lines of the old hondata setups, where you add an additional circuit board, but basically lets you have full control though
Old 01-31-2011, 11:04 PM
siularbar's Avatar
Can't wait for more videos and details!
Old 01-31-2011, 11:41 PM
handsom-hustla's Avatar
def looking forward to comparing dyno runs w and w/o. People will most certainly jump on this with the extra confidence bc of your progress and dedication.. Now get some sleep and continue the "TLdream".. Great work and best of luck..
Old 02-01-2011, 01:35 AM
Registered Member
Toddy's Avatar
Would this be able to display the data it shows on the laptop on a Car PC Screen or OEM Nav screen? Can't wait to see what this opens up for N/A applications.
Old 02-01-2011, 06:32 AM
KN_TL's Avatar
True, I was speaking more for most of the crowd here who limit themselves to a couple grand at most for performance mods.
Mention it. We need quite a few people who are interested.
Old 02-01-2011, 06:37 AM
KN_TL's Avatar
The stock ECU is still in place but the new ECU is in total control.
Old 02-01-2011, 08:40 AM
TLdream's Avatar
The software is just like any other "stand alone tuner software" It looks to be a windows based program. So if you had a car pc, or a pc/laptop in the car and doms nav to dvd, you should be able to display it on the the in car screen.
Im thinking in the end of things the stand alone is going to yeild more hp/tq than the standard $1200-$1500 full exhaust systems. With both systems, i could see the 3.2 6mts, making as much or more hp than the stock type s 6mts.
In a TL it will be run as a duel ecu setup. You need the factory ecu if you want to keep your cluster working correctly, and it also controls the DBW. The DBW system is part of the traction control system.
Although the factory ecu is still pressent, it has no control over the engine itself as far as timing and fuel go.
Old 02-01-2011, 09:13 AM
KN_TL's Avatar
I found that TunerStudio is also Linux/MacOS compatible. I am setting up a Mac Mini to go into my TL and bought Win7 and VMWARE Fusion just in case it was Windows only. I am going to try both to see if there is a difference.
But it still sounds the same
Old 02-01-2011, 10:25 AM
gerzand's Avatar
Now I can complete my build. Yessssssss!
Old 02-01-2011, 02:38 PM
All motor
Sonnick's Avatar
This looks awesome. I'm assuming it will work for the Accord motor as well?
Finally the R&D was put to good use! AWESOME job J&R and all who put time/$$/effort into this! This is exactly what the J series needs!!!
Inaccurate is 100% right. This will allow us to fine tune a cam which really opens up NA potential. It also is a great option for boosted guys that want the most out of their setup!
Any estimate on when the guinea pigs will be tested?
Old 02-01-2011, 02:41 PM
bmeyer's Avatar
I'm guessing some time around late February or March.
Old 02-01-2011, 04:27 PM
KN_TL's Avatar
That is the target.
Old 02-01-2011, 04:31 PM
J36Twingt28r's,nextgt30r
tenzingsherpa's Avatar
Mad props, man!
oh hell with the timing advancing avaliable i'll try it on my j36 stroker motor, plus with my kms valvetrain i can rev up to 8k rpm with this!!! lol
Damn Jandr i totally wanna see some more vids when this is fully tuned and some runs!!! im looking for something just like this being able to use ac, drive by wire and yet have complete control of the engine.
Props Jandr cause this looks really promising, and you may be seeing me as a customer really soon since i need something like this to tune my twin turbo stroker motor.
Old 02-14-2011, 05:30 AM
pass427's Avatar
Please bAre with us as we are working towards our release date in march ,we just have a few things we are working on to complete this project so please stay tuned ...
Old 02-17-2011, 08:26 PM
acuratl732's Avatar
Would I need the aem fix also or can I just run this
Old 02-17-2011, 08:38 PM
pass427's Avatar
This would be all you would need ,this will be a full programmable unit ..
I've been off the forum for a little but I'm pretty positive everyone understand the reason for that all the spare time is been spent working with new ecu getting familiarize so when it's released we will be able to offer help or technical support if needed ,and on top of that we had a few set back which we've overcome ....
One thing I can promise is a programmable unit that will satisfy all our needs n/a or forced induction ..
Old 02-21-2011, 08:01 PM
REDLINERAV's Avatar
"Who will be the guinea pigs to test it?"
I am one of them
Old 02-21-2011, 08:26 PM
pass427's Avatar
Redlinerav is our types full bolt on car which we will be using for testing if I'm not mistaken after all his bolt on and stock catback exhaust his car laid down an impressive 297 whp before ...
Darin types will be running ecu as well with jandr turbo kit ....
Anothe candidate will be jandr new shop car a 95 Integra with j32a3 motor and 6speed trans ...currently in progress thanks to tldream for all his donation towards this project which is been a great help we should be able to get good feed back on the ecu and daily functions on all different setups..
Old 02-22-2011, 11:03 AM
I got the Shifts
phee's Avatar
Let me know if u need a 6 speed 2nd gen with an automatic ECu to test. (most common swap setup)
I have money to buy the unit
Old 02-22-2011, 11:23 AM
jiga21's Avatar
+1
pass427's Avatar
Phee I lost all my contacts shout me a text
Old 02-22-2011, 03:58 PM
B A N N E D
Ricky Pounds's Avatar
The wait has been to long!! LET'S HOOK IT UUUUUUP!
Sweet!
Quick Reply: New ECU preview
