Comptech Short Shifter Install/pics 3G Garage #A-086
Old 01-01-2010, 11:55 PM
  #201
vonkristian's Avatar
Originally Posted by ABP_04TL
wat u waitin for? hurry up do it... is pretty straight forward
DO IT DO IT!!!
wooo finally i did it!!!!put the short shifter on with the help of my friend and 3 hours!!!!lololol
but i kinda feel like 1,3,5 is the same and 2,4,6 are realllllly short trows!!!!
o welll ill drive for a bit and see if i need to make any future changes to it.....
diff need to do this to your tl!!!!!!
Old 01-02-2010, 11:20 AM
  #202
6-SPEED LOVER
ABP_04TL's Avatar
Originally Posted by runna03
For those of you that installed the bushings kit, did you purchase 2 kits? - Or will 1 kit be sufficient to replace the both locations of bushings. (Engine Bay, under Shiftbox Assembly)
Thank you
Also hoping jmbnova logs back into his account so the DIY pictures can be seen again. Would love to do this install via a helpful guide vs. Comptech instructions.
all u need is one kit
Old 01-02-2010, 11:22 AM
  #203
6-SPEED LOVER
ABP_04TL's Avatar
u need to lower (cut) ur shift lever!! which i have mine cut but wanna go bak to stock shift lever...
Old 01-03-2010, 08:57 AM
  #204
AM MT Navi
shotcaller88's Avatar
why are you going back to stock?
Old 01-03-2010, 05:14 PM
  #205
6-SPEED LOVER
ABP_04TL's Avatar
i want that soft oem feel... when u cut the lever, it gets stiffer and ofcoarse a shorter throw....
im not wanting to change it cuz is bad i just wanna go bak to OEM feel me...
Old 01-03-2010, 06:13 PM
  #206
JwongTLS's Avatar
put a weighted shift knob, that should solve the problem
Old 01-03-2010, 08:52 PM
  #207
6-SPEED LOVER
ABP_04TL's Avatar
I have one.... Ricks voodoo sk2 pearl mag knob... I just want the stock lever bak on lol
Old 01-05-2010, 03:03 PM
  #208
How may I help you.....?
jmbnova's Avatar
Bumpitty bump.
Sorry gents... Didnt know the pics had dropped out.
Old 01-05-2010, 05:06 PM
  #209
AM MT Navi
I've wanted a comptech short shifter for a while now. Some people complain about notchiness and with the pos 3rd gear synchro, I'm just really hesitant. IMO Acura would try to blame the SS if I did go to them about issues with 3rd.
This and the UR Pulley are the last couple mods I'd like to pick up. I'm just skirred!
Old 01-05-2010, 07:38 PM
  #210
6-SPEED LOVER
ABP_04TL's Avatar
DONT B SCARED!... ur 3rd Gear, just get the GM Sychro and ur good... CT has never felt nochy on my TL and never will lol... so dont b scared and DO IT! DO IT!! same with the UR Pulley just get the Stock Size one and u b fine
Old 01-05-2010, 08:27 PM
  #211
jmbnova's Avatar
I had a full tranny replacement due to the third gear issue and it was done after my SS had been in the car for a long time. No issues.
I take that back. While at the dealers waiting on the tranny, some fuckers used a pry bar on my door, jacked my rims, and dropped the thing onto car batteries which also grounded the car on the rotors! Asswipes
Tranny was good to go though....
Old 01-07-2010, 12:06 PM
  #212
runna03's Avatar
Originally Posted by jmbnova
Bumpitty bump.
Thanks again jmbnova, will be installing the SS today.
Good lookin'
Old 01-07-2010, 12:18 PM
  #213
Regions Leader
trancemission's Avatar
Holy crap jmb, where the hell you been??
comptech short shifter with weighted shift knob > *
Old 01-08-2010, 07:19 PM
  #214
runna03's Avatar
Took about 4 hours for complete dis-assembly because certain parts were a bitch to take out...
Going to put everything back in tomorrow, can't wait to try it out.
Thank you again jmbnova for the excellent DIY guide.
Old 01-09-2010, 02:46 PM
  #215
runna03's Avatar
Just drove around the area, love the feelin' of SS - a must mod for anyone without a doubt.
Thought I'd add a few notes for anyone doing this soon :
- the hex screws on the comptech SS are 3mm.
- metal clip on linkage cable can be pryed straight up just as described in the DIY guide, but you can pry directly from where it looks like there is a washer there. It is actually 1 whole piece together. Used a flat head screw driver.
- and one last note about the hex screws on the SS, make sure you have clearance putting it on. This would be when you already have the loctite on the inside and ready to go. Just have the screws adjusted accordingly and the SS should fall in nicely with minimal pressure added.
Good luck!
Old 03-16-2010, 11:08 PM
  #216
Djr587's Avatar
Well I didn't need to put a shift in, BUT this post make my trim replacement a snap. I was also able to replace the pesky LED illumination inside the heated seat toggle. THANK YOU !!!
Old 05-05-2010, 07:20 PM
  #217
timportspeed's Avatar
i can't get the bushing off the ball!! so frustrating!! my short shifter didn't come with the tool, i used a wrench and dam bushing too hard to get off
Old 06-18-2010, 08:15 AM
  #218
Waltah's Avatar
the comptech short shifter for the tl works for base and type-s models correct?
did a search, and the answer is yes. thanks folks
Old 06-29-2010, 08:45 PM
  #219
Waltah's Avatar
holy crap, what a PIA, but totally worth it.
ive got some battle scars unfortunately. busted up one knuckle and 2 other cuts.
Old 09-12-2010, 04:34 PM
  #220
anthracite_ftw's Avatar
I just installed the short shifter then went to reassemble everything, and discovered I lost the metal clip that secures the linkage to the front of the housing. Have been searching for about an hour, and I'm not sure what to do if I don't find it, since it's a pretty essential piece.
Old 09-15-2010, 12:16 PM
  #221
Former Sponsor
MrHeeltoe's Avatar
You can get a new one from the dealer...but yeah you probably want to find it because it will take days for a dealer to get one.
Old 10-12-2010, 07:19 PM
  #222
gt1
` . ' . SUV haterrr
gt1's Avatar
I've had a short shifter in my TL for 5 years- longer than this thread existed. Until today I had been very happy with the upgrade. Today my wife pulled from a garage. When she tried to shift in 1st she felt that the shifter was very loose. She managed to get the car back in the garage. When I got home, the shifter was moving freely and felt disconnected. When I took everything apart, I found that the factory shifter broke! The ball on it's end was stuck inside the short shifter. You can see it in photograph below.
I guess that short shifter creates an additional load on the factory shifter. I can't explain it otherwise. My wife isn't that strong handed. So now I need to get a replacement shifter- it comes assembled with that huge plastic housing. I will probably need a new short shifter. The broken part stuck inside is glued with Loctite and I might not be able to remove it.
The car will be out of service for a while, and I'll have to commute on a motorcycle. Of course the forecast is for some cold rain. We are still lucky that it happened on our driveway. Could be stuck who knows where.
Old 10-17-2010, 03:48 PM
  #223
rzarezai's Avatar
Great write up. I actually used this write up to install my iSimple ipod kit as many of the same panels were removed. I am however having one slight problem and need to get back in there. How ever, I am having trouble removing one of the screws that connect the center console to the gear shifter panels. I have removed the two screws in the armrest without a problem and the screw on the passengers side, but the only thing that happens with the other screw on the Drivers side is that it turns, but does not lift up. So you can keep turning it and it won't budge. Any help here in getting that screw out so I can slide the console back?
Old 10-25-2010, 07:56 AM
  #224
gt1
` . ' . SUV haterrr
gt1's Avatar
Contrary to the instructions included with the shifter, there is no need to remove left and right tunnel covers. They can be pushed outwards just enough to free the center console.
Old 10-25-2010, 04:20 PM
  #225
cvc7395's Avatar
are there any additional parts needed ?
hello all.
This is indeed a nice write up and I have ordered the CT SS for my ride as well.. a quick quesiton though, are there any additional parts needed , such as a heavy shift knob (is this a must or can i just use my current shift knob). are there any adjustment needed for the clutch? once the ss is installed and all panels are assembled, does the stick shift same height or lower? does the leather fabric need any modifications?
thanks in advance for answering these questions.. as i am anxiously waiting for the part to arrive so that i can put it in...
Old 11-04-2010, 01:15 PM
  #226
gt1
` . ' . SUV haterrr
gt1's Avatar
You don't need anything else. Shifter height stays the same.
Old 11-27-2010, 12:51 AM
  #227
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I can't believe I've been sleeping on this mod this whole time. I think I may do the corsport aluminum bushings and the ss at the same time. Then a countersunk shift knob!
Old 11-27-2010, 01:55 PM
  #228
A-SPEC 6MT
jrocka312's Avatar
DO THIS IMMEDIATELY!!! You will not regret it.
Old 11-27-2010, 03:21 PM
  #229
If that's not encouragement, I don't know what is! LOL...
Gonna have to order it...thinkin about going with a nice glossy black monsterknob shifter knob to top it off!
Old 12-02-2010, 10:20 AM
  #230
anyone ever see THIS type of short shifter? The year TL matches up, didn't know if this was better or worse than the regular comptech short shifter...
Old 12-02-2010, 06:18 PM
  #231
MAS
MAS's Avatar
Just did the CT short shifter today and WOW what a difference. Feels so precise. Pics of my install will soon by up in my photo thread
Old 12-02-2010, 08:18 PM
  #232
Ordered mine along with a
"monsterknobs" 2" resin shifter. Should look CLEAN!
Old 12-12-2010, 02:47 AM
  #233
Installed today and all I can say is WOW...shifting is so precise and much shorter. Thanks for the tips everyone.
Old 12-12-2010, 02:49 AM
  #234
GT1,
Are you sure you put loctite on the base portion and the ball and shoved it ALL the way in. From what I see in the pics, even if you had snapped the OEM ball off at that point, if it were pushed all the way down AND had loctite and the 2 bolts tightened on the sides there is no way it would have just fallen off like that.
I think you may not have pushed it all the way down. I had to push HARD to get mine to sink all the way in.
J.
Old 12-12-2010, 09:45 AM
  #235
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
this is def gonna be my first mod of the new year!!!
Old 12-12-2010, 12:16 PM
  #236
You will be very happy...I'd be the first to say that I would think this mod is stupid...but man, it actually changes the driving experience. It is amazing.
Old 01-09-2011, 01:28 PM
  #237
westas2's Avatar
Installed this weekend - everything came apart and went back together perfectly. Thanks for all the tips and great write up. Love the way it feels - great mod...
Old 01-10-2011, 01:45 PM
  #238
Former Sponsor
MrHeeltoe's Avatar
Don't! I yanked mine for these and never looked back. The Hybrid Racing parts we tested worked amazingly.
New Shifter Cable Bushings…Out With Solid Aluminum, In With Hybrid Racing! HeelToeAuto.com's Pit Board
Old 01-10-2011, 01:49 PM
  #239
Former Sponsor
MrHeeltoe's Avatar
GT1 you look like your shifter adapter was not pushed down all the way. If you are positive it was I'd say this was very odd indeed. Never seen it happen in 5+ years.
Old 01-16-2011, 08:57 PM
  #240
^^^I agree totally, it's COULDN'T have been totally pushed in or it wouldn't have been able to break there.
Anyway, just resaw this thread, thanks for the info...good to know about the hybrid bushings etc...I may consider those AND the clutch cable too...
J./
Quick Reply: Comptech Short Shifter Install/pics 3G Garage #A-086
