View Poll Results: best to dynamat or not????
yes dynamat trunk
62.50%
no dont dynamat
0%
no dont dynamat just do this..........
37.50%
Voters: 8. You may not vote on this poll
Dynamat or not??
Old 04-23-2012, 01:06 PM
Westside_TL's Avatar
Dynamat or not??
question to all that have and those thinking about it?? 07 tl base when added a sub in trunk should we add dynamat to the trunk or no or try something totaly different?? also note this is for trunk rattle not back dash that problem fix thanks to great people here!!!
Old 04-23-2012, 01:08 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
second skin is a little better and easier to use than dynamat.
i would recommend it for sure. one tip, try and pinpoint exactly where the rattles are coming from before you start laying the stuff down. it works great tho...good stuff. make sure you get the roller tool as well. makes laying the stuff down a breeze.
Old 04-23-2012, 01:26 PM
so ur vote is option 3?
Old 04-23-2012, 01:28 PM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
http://www.secondskinaudio.com/
Damplifier then Overkill. Luxury Liner on the doors, roof, floor.
Old 04-23-2012, 01:31 PM
BANNED
what options?
oh i see it's a poll...gotcha.
Old 04-23-2012, 04:39 PM
but the question was for trunk not whole car
Old 04-23-2012, 04:43 PM
maharajamd's Avatar
Then it's pretty much just the Damplifier.
Old 04-23-2012, 04:44 PM
Coolest A-zine Member
Trunk Monkey's Avatar
Sound Deadener Showdown CLD Tiles or Second Skin Damplifier Pro
Like said before, play music and listen for rattles, then attack that location. Flat surfaces are where you get rattles/resonance, not curves.
Old 04-23-2012, 06:03 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
I've had great luck with both Second Skin and Dynamat but the second skin seems to work slightly better for a given weight.
For the trunk, removing the license plate frame and using all 4 screws for the plate will take care of most of the rattles. I would to this first and see if you still need it.
Old 04-23-2012, 07:15 PM
Mug
Mug's Avatar
I thought I read somewhere on here that it could be the counter weight under the trunk lid liner that rattles too.
AcuraKidd
04-23-2007 06:33 PM
digital_04
09-16-2006 11:32 PM
ASuddenSilence
07-17-2005 06:15 PM
ReflexRacing_com
10-24-2002 12:49 AM
ZeroPSI
06-20-2002 05:22 PM
Quick Reply: Dynamat or not??
