DIY- '07 TL A-spec Front Lip Install 3G Garage #E-002
Old 08-19-2007, 03:28 PM
1meand's Avatar
I have a pdf of the actual instructions from Stephen Bradburn of John Eagle Acura. I don't know exactly how to post that. I can email it if anyone is interested.
Ok, you start by removing the front bumper https://acurazine.com/forums/showthr...t=front+bumper It's the same for an 07 except you have to unplug the fog lights and remove a clip holding the fog light wire.
Here are the parts that come with the lip. 2 Brackets, 8 self tapping screws, 2 female clips, 2 seals, 4 spring nuts, 2 long clips, and the lip.
Step 1: Drill a hole in the sides of the bumper were it's already marked with a circle with a + in the middle of it. The instructions say use a 4mm bit to go from the inside out and a 12mm bit to drill from the outside of the bumper in. I used a 5/32" bit first, then I used a 3/8" bit second and it worked fine. This hole is for the black zip tie looking clips that are attached to the lip. Drill both sides.
Step 2: In the lower middle of the bumper are two more plus circles. Use a 4mm or 5/32" bit to drill two holes.
Step 3: Place a spring nut over each of the holes with the curved part of the nut facing up.
Step 4: On the edge of the bumper that faces the front tires you will see another plus circle. You will use a 4mm or 5/32" bit to drill a hole. Be careful when drillig this hole! If you push too hard or drill too deep you will drill through the bumper. Repeat for the other side.
The directions say to hold the bracket up and mark the hole, but it worked out fine to just drill where the plus circle was.
Step 5: Place a spring nut over the holes and mount the bracket with a self-tapping screw.
Step 6: There are 4 pieces of double sided tape on the lip. You need to peel a little piece of the backing up and use masking tape to stick it to the outside of the lip. On the sides, peel from the back or the part closest to the tire and on the front peel from the outside towards the middle. For now just peel a small piece, enough to get a hold of after you mount the lip.
I added some more tape under what was already there, just for piece of mind.
Step 7: Now you can put the lip onto the bumper, making sure that the black zip tie looking clip goes into the 3/8" holes that you drilled. You will have to apply some pressure to get the ends of the lip around the ends of the bumper.
Step 8: Use two of the self tapping screws to secure the middle of the lip to the middle of the bumper.
Step 9: Attached the seal and then the female clip onto the zip tie looking clip
Step 10: Using the self tapping screws attached the lip to the bracket.
Step 11: Now re-install the front bumper. You will use all the same screws and clips that you removed except for on the two outside metal brackets of the lip. You will use the supplied long clips.
Step 12: Pull the backing out from the double sided tape, being careful not to cut or rip it on the lip. It will stretch, but I didn't have a problem with it ripping.
And here's the finished product. The 07 lip doesn't have any plastic showing, it's all painted as you can see.
If anyone has any questions, just let me know.
The following 5 users liked this post by 1meand:
JD TL-S (06-01-2012), Midnight Mystery (02-11-2022), robocam (08-25-2015), rockstar143 (02-28-2016), Teo_cleanNlean (12-28-2014)
Old 08-19-2007, 03:37 PM
aznbo187's Avatar
Nice write up! This version of the a-spec for the base looks much classier than the type-s a-spec kit.
Old 08-19-2007, 03:43 PM
FizzyStatus!
ballinfizzle89's Avatar
Yeah I agree with aznbo with the classy part!
Great write up though man, and pictures really help out! I'm definitely feeling the type s grill by the way
Old 08-19-2007, 04:08 PM
aznbo187's Avatar
Old 08-19-2007, 04:28 PM
1meand's Avatar
Thanks guys.
Yeah, I just didn't like the standard grill.
Old 08-19-2007, 05:02 PM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
the funny thing is in black since you can barely notice it the tl s a-spec looks decent but def agree the base looks awesome
Old 08-19-2007, 06:00 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
I sent you a PM with my email address so you can send me the PDF.
Old 08-19-2007, 11:27 PM
Dont Touch My Car !!!
Tonywp75's Avatar
Ron A ..........PM me. I got the PDFs for the front lip, side skirts, and rear under spoiler.
Complements of : Stephen Bradburn
John Eagle Acura Parts
281-589-0326
800-441-6878
Old 08-20-2007, 03:40 AM
datmrman's Avatar
Nice. Definitely Garage worthy material.
Old 08-20-2007, 06:47 AM
How may I help you.....?
jmbnova's Avatar
nice write-up man..
Old 08-20-2007, 06:51 AM
Administrator
Ron A's Avatar
281-589-0326
800-441-6878
PM sent. And this will all go into the 3G Garage.
Old 08-20-2007, 05:16 PM
Tonywp75's Avatar
Sent
Old 08-20-2007, 08:47 PM
blacktls07's Avatar
Definitely looks better then the Type-S front spoiler.
Old 08-21-2007, 01:49 AM
blacktls07's Avatar
Noob question, but would a non Type-S lip fit on a Type-S?
Old 08-21-2007, 04:44 AM
1meand's Avatar
No. The bumper angles up around the fog lights on a regular TL
and it angles down around the fog lights on a TL-S. There are some great pics in this post https://acurazine.com/forums/ramblings-12/magic-must-see-164666/ complete with the A-Spec kit.
Old 08-26-2007, 08:40 PM
08 TL & 12 ADV/ENT MDX
ziggyh22's Avatar
By any chance do you have the part numbers to that kit and any pics of cars with that whole kit instaled? Ive been searching everywhere for pics of cars with that kit on. oh and where did you order that lip from?
Old 08-26-2007, 10:45 PM
Tonywp75's Avatar
He ordered it from :
Stephen Bradburn
281-589-0326
800-441-6878
Just make sure to mention......Tony from AcuraZine sent you. So he will know where you are coming from.
Old 08-27-2007, 01:15 AM
ziggyh22's Avatar
Great thanks for the help Tony!
Old 02-08-2008, 03:16 AM
blah
Vietnastee's Avatar
Where are those PDFs that were went to Ron A? I'm having a hard time finding them.
Old 05-18-2008, 03:43 AM
8th Gear
KEVIN301's Avatar
Question O7 Tl-s
anybody know any bodykit for 07 tl type s? besides the oem kit and ronjons bodykit.
Old 05-18-2008, 02:21 PM
Too Fast TOO FURIOUS
enigmaos's Avatar
^there are some on ebay. not sure about fittment on TLS though.
Old 05-18-2008, 03:15 PM
07 TL's Avatar
im getting my aspec kit tomorrow.. nice write up
Old 08-02-2008, 12:43 PM
Stew4HD's Avatar
Received 1,092 Likes on 714 Posts
This DIY is the best! My kit came with no instructions, so reading through this one, seeing the marks the factory left for the kit.. easy!!
THANK YOU! I now have an '08 with the Aspec body kit installed! Pics to come.
Old 08-04-2008, 04:26 PM
NocturnalTypeS's Avatar
nice writeup
Old 08-04-2008, 07:40 PM
2010 WDP TL Tech
maxAmillion's Avatar
Would an 07 TL a-spec front lip fit on an 06? I like it better than the 06.
Old 09-25-2008, 01:33 PM
P1zzaman's Avatar
So this REPLACES the front? I thought it just adds to the front. If it adds to the front, is removing the front bumper necessary?
Old 09-25-2008, 07:52 PM
jnnyjuice's Avatar
it doesnt replace the front, its just an add on lip and yes removal of the bumper is necessary for installation
Old 09-26-2008, 10:21 AM
jdmlsvtec's Avatar
looks good nice write up clean look
Old 02-21-2009, 12:37 AM
cpgar11's Avatar
Yeah, I was looking for those PDF's as well and cannot find them. If anyone has these or know where they reside, can someone post a link? Thanks!
Old 02-21-2009, 06:35 AM
Road Racer / Solo Addict
EL BAN's Avatar
Thank you so much for taking your time to make this write up.
stillhere153 and others had been helping me sort out the lip I was going to buy and once I get it I know your write up will help me out a lot..
So I appreciate you taking your time to document this for us..
Old 02-25-2009, 01:45 AM
fansy's Avatar
Do you need alcohol to clean the part where the tape is gonna be? or just cleaning is fine?
Old 11-17-2009, 12:10 AM
samplemonster's Avatar
This would be the same for an 05 TL without any problems or weirdness, correct?
Old 11-17-2009, 08:31 AM
dwb993's Avatar
For anyone looking, the PDF instructions are here:
https://acurazine.com/forums/8328596-post/
Old 10-12-2010, 08:35 PM
Lonewhitestar620's Avatar
Hey can I ask how did you chrome your grills?
Old 04-19-2011, 03:38 PM
NSXCessive's Avatar
Originally Posted by 1meand
Thanks guys.
Was doing some random searching and found this information thanks very helpful. Will this 07-08 Base Lip fit an 04-05 with pretty much same installation DIY?
Old 04-19-2011, 07:02 PM
[x] FWCC [x]
tones160's Avatar
nice, i want my front lip now lol
Old 05-11-2011, 11:57 AM
Tebaz06TL's Avatar
thanks for the info. i'be been trying to figure out which lip i want to get too. so the lower grill area makes the difference. i have a base 06, does it matter which year of the aspec lip you get if its base and not type s?
Old 06-01-2012, 10:22 AM
JD TL-S's Avatar
Great Job and Photo's
Thankyou
Old 06-21-2012, 11:10 AM
TripleLex's Avatar
Awesome write-up... Thanks!
Old 04-07-2014, 02:00 PM
Jriddle8's Avatar
Could some one send me the pdf if you still have it?
Quick Reply: DIY- '07 TL A-spec Front Lip Install 3G Garage #E-002
