LKAS being stupid
Old 10-09-2015, 05:31 AM
Stew4HD's Avatar
Received 1,092 Likes on 714 Posts
Cool LKAS being stupid
The LKAS in my car is stupid. I am comparing this to the TLX. In the RLX, LKAS will drift to the right side of the lane, barely cross over the stripe then over correct to the left and do the same thing on the left side. It won't handle much of a curve either.
The LKAS in the TLX I came from kept the car fairly centered and didn't drift over the stripes. It also handled some decent curves (nothing tight or hairpin).
Is this normal on the RLX or is, as I suspect, something is awry?
Old 10-09-2015, 06:49 AM
Received 16,260 Likes on 11,971 Posts
older tech
congrats on the RLX btw, didnt know you jumped ship until yesterday
Old 10-09-2015, 07:20 AM
Stew4HD's Avatar
TSK. TSK.. A '16 model with older tech than the '15? It wouldn't surprise me
Thanks, I didn't intend on changing cars YET AGAIN! This crap started with bad luck I was having with the 4G! I'd have been better off taking that car to an exorcist!
Old 10-09-2015, 07:24 AM
pgeorg's Avatar
Hi Stew4HD,
This is not normal, at least for me it works as in the TLX and MDX. One thought is to check the Road Departure Mitigation Setting is NOT set to wide? I say this because the LKAS and RDM is integrated on the 2016 RLX (Acurawatch), and it was not available on the 2014s-2015s RLX. Try to turn RDM to warning only, and see if it makes a difference. It may also need to be re-calibrated, because it was not set correctly from the factory.
Sorry i can't help more......
Stew4HD (10-09-2015)
Old 10-09-2015, 07:26 AM
pgeorg's Avatar
I am pretty certain that the 2016 has the same tech (Acurawatch) as the 2015-2016 TLX and the 2016 MDX.
Old 10-09-2015, 07:32 AM
relax fellas, i'm only giving him poopoo.
neuronbob (10-09-2015)
Old 10-09-2015, 07:44 AM
Stew4HD's Avatar
Originally Posted by pgeorg
Hi Stew4HD,
I'll check that setting, thank you!
Justn and I go back a ways. He gives me crap cuz he can! It's all in good fun. He just doesn't like stupid questions and/or people
pgeorg (10-09-2015)
Old 10-09-2015, 08:41 AM
Grandpa
George Knighton's Avatar
Received 2,609 Likes on 1,475 Posts
My LKAS works okay, but I have to admit that this is the first car that I've owned with LKAS. My previous car was a 6-6 4G TL, so of course a lot of these systems weren't available with the clutch.
I have noticed that it is dangerous to rely on LKAS with sharper curves and at higher speeds.
For me, the combination of LKAS + ACC is a huge stress reliever, allowing me to make longer trips without stopping and allowing me to arrive at destinations hours away feeling well. And then I feel a lot better getting back to the country at night, even if I've had to fight traffic...because the car's doing most of the traffic fighting.
The 5G RLX, remember, was supposed to be released before it was. As two years slipped by without being able to release it, the electronic world moved on to another generation.
So, yes, indeed, you have less memory and slower processors for some things in a 2016 RLX than the 2015 TLX has.
It's just the way the car design cookie crumbled in this case.
I do not at all regret owning this car. Any car that'll get to 60 in five seconds while weighing 4400# and getting 31.3 mpg after 22,000 miles is more than okay in my book.
But I'm realistic about it. It's not a super car, it's not an ultimate-at-anything car.
It's just a very reasonable choice, that's all.
The compromise with LKAS and ACC is just one of many, many compromises.
Don't focus on it too much or you'll be buying a new car every year!
The following 3 users liked this post by George Knighton:
fsmith (10-09-2015), neuronbob (10-09-2015), victorber (05-06-2016)
Old 10-12-2015, 06:13 PM
pcloadletter's Avatar
LKAS likes to keep right and does not like narrow roads even with clear markings. One odd thing noticed today is that is stays engaged below 45 mph.
ACC does not like approaching stopped traffic. For some reason it flashes brake when slowing down.
New trick is to tap the ACC set button when approaching a red light with slowing traffic instead of using the brake pedal.
I believe ACC uses more aggressive regen, can this be confirmed?
Type S Zero
02-17-2016 02:37 PM
Trav2390
10-20-2015 07:30 PM
Tonystlx
5G TLX Problems & Fixes
09-20-2015 11:47 PM
TL-GIXXER
09-18-2015 10:25 PM
Quick Reply: LKAS being stupid
