Bluetooth is locked
Old 02-14-2020, 02:51 PM
5th Gear
AnthonyArrollado's Avatar
Bluetooth is locked
Can somebody help me? My Bluetooth was working and synced to my phone but now it is saying it is locked!? It won't let me connect with my phone anymore🤔
Old 02-14-2020, 03:21 PM
RTM
RTM's Avatar
hmm, "bluetooth locked" doesn't come up when searching the manual. What is the exact wording. Bluetooth comes up 182 times.
Old 02-14-2020, 03:47 PM
5th Gear
it's says the system is locked... What is the 4 digit passscode...
Old 02-16-2020, 08:26 PM
EuroRspec's Avatar
Sounds like your car battery was disconnected and you need to enter the radio code.
Try this
https://radio-navicode.acura.com/
Old 02-16-2020, 09:30 PM
5th Gear
I have my codes for radio and navigation... those still don't work!
Old 02-17-2020, 11:20 AM
Bonehead
ScottyWM's Avatar
Just a thought... make sure you have the radio knob "On" when entering the codes. Took me an hour or so to finally figure that out.
Old 02-17-2020, 11:39 AM
5th Gear
Radio was on and still say my code is incorrect!?
Old 02-17-2020, 11:58 AM
RTM
RTM's Avatar
The radio and Nav are both working, right?
My phone asks for a bluetooth pairing code (often 0000) to pair to the car. Car displays a message that the code needs to be entered in the phone. Is this your message, or is it asking to enter a code in the car?
Old 02-17-2020, 12:09 PM
RTM
RTM's Avatar
OK, here we go, But I thought you said you have Nav, and this supposedly doesn't apply:
The HFL (Hands Free Link) system is locked and the pass code has been lost or forgotten (without navigation)
1 - Connect the HDS to the DLC (Honda Diagnostic System)
2 - Turn ignition On
3 - From Body Electrical menu, select HandsFreeLink
4 - Select Misc Tests, then select Pass Code reset.
5 - Follow the HDS prompts to reset the pass code
And the difference between passcode and pass code matters to Adobe Reader.
Neech
Technology
11-01-2005 08:36 PM
undergnd
Technology
12-24-2004 12:01 PM
Neech
Technology
08-21-2004 12:36 AM
beerknurd
Technology
12-30-2003 03:41 PM
GTPandTL
Technology
06-15-2003 12:29 AM
Quick Reply: Bluetooth is locked
