02 memory seat
Old 08-23-2010, 12:57 AM
02TL4ATL's Avatar
02 memory seat
my 02 tl didnt have memory switch in the door panel when i bought it about two years ago. it has been in an accident prior to my ownership. Could the door panel have been replaced with a 2000-01 door panel?
Old 08-23-2010, 03:25 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
does your owner book say 02s have memory? iirc 03 has it but cant say on before that
Old 08-23-2010, 10:32 AM
totaledTL's Avatar
My '02 TL-S has memory seats.
Old 08-23-2010, 11:03 AM
Bonki' Ehrite!
ANC297's Avatar
My 02 has memory seats...
Old 08-23-2010, 11:12 AM
01tl4tl's Avatar
02TL-- register with acura.com owner link and you can read the owner manual there- specific to each year
http://owners.acura.com/registration...erstepone.aspx
also register at 1 800 382 2238x5 need cars vin for both those systems
800 will ck if recalls are completed
ask the parts guy at your local dealer if its possible to interchange that year panel
Old 08-23-2010, 11:16 AM
totaledTL's Avatar
Unlikely a parts counter guy could determine that, unless he has done it. They look at part #s- doesn't match, not the same part-
Old 08-23-2010, 12:09 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Did 02-03 non type-s have mem seats or was that only type-s. I dont remember
Old 08-23-2010, 01:24 PM
02TL4ATL's Avatar
hi thanks for chiming in guys. so i just finished registering my acura and i asked the person to find out if the 2002 base came with memory seat and he said it did. So now the new question is any idea how much the part for the memory seat cost?
Old 08-23-2010, 03:46 PM
Bonki' Ehrite!
ANC297's Avatar
Mark the date folks! Kris is finally stumped!
And yeah, both the type s and the non type s have memory seats.
And if the car has been wrecked and repaired, I'd venture to say that the shop cheaped out and put older panels in...So all you need is probably the actual buttons, Im sure the seats still have the module in them.
Old 08-23-2010, 05:44 PM
01tl4tl's Avatar
never trust the minimum wage phone answering drone at acura 800
they are looking in a book and have been know to be wrong..
especially when you think its warranty issue~
the Big Book of NO!!!
Old 08-23-2010, 05:46 PM
fsttyms1's Avatar
First take your door panel off and see if the wiring is there. If it is, try to locate a used door panel. It would probably be cheaper and easier.
Old 08-23-2010, 05:47 PM
fsttyms1's Avatar
Its actually built into the multiplex, seat and ECU. All 3 control it. The part on the door is just a switch
Old 08-23-2010, 06:44 PM
02TL4ATL's Avatar
Yeah the wire is in the when I took off the door panel to connect some plugs that my mechanic unplugged for some odd reason . Do you guys think i can just buy this http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
and put it into my current door panel? cause im not sure if the current door handle hole will fit the new one.
Old 08-23-2010, 08:49 PM
fsttyms1's Avatar
I dont know if the door panels are the same or not. I havent seen them side by side.
MrHeeltoe
20
02-23-2023 01:54 PM
tsx_boy
12-13-2019 08:33 PM
MrHeeltoe
09-29-2015 10:43 PM
hashbrown
09-29-2015 12:13 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: 02 memory seat
