It Finally Happened My 2001 CL-S Transmission Failing 146K! I NEED YOUR HELP
Old 12-29-2014, 11:53 AM
YungMoola15's Avatar
Ok guys so basically my tranny just started failing probably in its first stages.
It started off with a loud crank noise when I would put it into park.
Then, switching into gears would take couple seconds to engage.
Now, the car hesitates and a lot of slipping while driving.
All this started 2 weeks ago and I haven't been driving the car much since semester is over. I did drain 3 qts dw-1 but still nothing.
So basically I just want to know what's the best possible method to prolong the life for another 15k? (If possible) Would driving it in sport mode (manual shifting) help at all?
Lastly, do you guys think its worth rebuilding it? How much would it cost? Or should I try to sell and buy something else?
It really sucks because I meticulously took care of the car but still the worst has occurred. I even had brand new rotors, brakes and spark plugs ready to install in the summer.
Old 12-29-2014, 12:45 PM
3.5 psi
gnuts's Avatar
go to the TL side and look into the accord tranny swap. If you decide to fix it, don't put in another shitty trans. You'll have to do some cost benefit. Selling it with a broken trans you'll get nothing for it. Then you have to buy a new (used) car. Or you could put in $2,000 and get a realible trans. (i'm ballparking that number).
If your trans is dying, there's no way you'll be driving it for long. Good luck with everything.
Old 12-29-2014, 01:06 PM
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
I got an 07 accord v6 transmission for 1000$, installed it in my 2000 tl with a friend and it drove fine till I sold it. All you have to do is swap the upper oiler cooler/warmer and filter assembly, the range switch, and the third and fourth gear pressure switch harness. If you have a base model you have to loop the power steering rack.
https://acurazine.com/forums/second-...n-swap-905115/
Old 12-29-2014, 01:16 PM
Yeah that's what I was thinking too. Most I would probably get is $2000 if I'm lucky. The car is in tip top mechanical shape other than the transmission. The thing with putting an accord transmission is I don't have any mechanical knowledge (other than small oil changes, filters, lights, etc..) how do I convince a shop to install it?
Old 12-29-2014, 01:17 PM
Yeah that's really nice. But I don't have any mechanic friends other than my regular mechanic but he wouldn't do it for free. If I get the transmission how much do you think labor would cost? How much did you end up selling the car for and at what mile?
Old 12-29-2014, 01:18 PM
Depends on the shop I have seen labor charges from 500 to 1000 most of the time.
YungMoola15 (12-29-2014)
Old 12-29-2014, 01:44 PM
Terragotti's Avatar
Had an 06 Ody trans installed by one of my friends on my CL like 60,000 miles ago and still going.(he works at a garage in Hyattsville , MD), he might start at 5 and work you up but he wont kill you if its straight plug and play like mines was.
Old 12-29-2014, 01:56 PM
3.5 psi
gnuts's Avatar
I know i've seen CL's for sale around here with a blown tranny and they are asking $1,000 and under. I wouldn't expect close to 2K.
Old 12-29-2014, 04:00 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Just pick up a used 06-07 Accord V6 trans and have a shop install it. Call around and ask. Its a 4-6 hr job tops Dont call it a "SWAP" when talking to shops about install charges. Shops hear "Swap" and either turn you away or start jacking up the prices.
Old 12-29-2014, 04:59 PM
WOW I live in Northern VA in Gainesville. Hyattsville is like an hour away but I wouldn't mind driving if your friend could help me out with putting an accord transmission in my CL.
Old 12-29-2014, 05:00 PM
Where did you buy the transmission from? How much did you end up paying after everything?
Edit: LOL I read it "Just PICKED up..."
Old 12-29-2014, 05:01 PM
I know and if it's $1000 then selling it definitely isn't worth it because the timing belt was just done 10k ago. Car is super clean inside out.
Old 12-29-2014, 05:09 PM
In the meantime which driving method D or Manual Shifting help get more life?
Old 12-29-2014, 05:31 PM
Terragotti's Avatar
I think neither at this point, I know mines was about to end and I could only drive it under 25mph and less than a quarter mile before it would die out, inbox me for that number
Old 01-01-2015, 11:59 AM
YeuEmMaiMai's Avatar
the accord trans is P&P that the shop has to do is remove old trans
swap sub harness from old to new trans
swap range switch from old to new trans
install a NEW oil to water cooler for a TL/CL onto trans
bolt up replacement transmission
Old 01-01-2015, 02:16 PM
01RedCLS's Avatar
I had a shop put mine in - 57k '07 Accord tranny .. works GREAT and got my car back vs. selling it! Nice to have a paid off ride the last 5+ years that still runs amazing.
Yikes
05-03-2021 04:29 PM
jspangan
ILX
19
08-30-2016 05:37 PM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
usual suspect
2G TSX Photograph Gallery
12-07-2015 10:52 AM
gqdabien
09-08-2015 11:41 PM
Quick Reply: It Finally Happened My 2001 CL-S Transmission Failing 146K! I NEED YOUR HELP
