2004 TSX HID - Is there a relay? Where?
Old 06-15-2017, 11:37 PM
2004TSXIan's Avatar
2004 Acura TSX. Low beam issue. isolated that prob is not ballast or bulb. Comes on sometimes with the switch being turned on/off/on over and over. totally unpredictable. Question: Fuses are good. Is there a relay that might be going out or getting stuck? If there is no relay, its got to be the igniter due to me isolateing the problem due to trial and error. Please advise
Old 06-16-2017, 08:17 AM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
This thread has been moved from the 3G TL Problems & Fixes Forum to the car specific forum applicable to your vehicle.
Old 06-16-2017, 09:20 AM
TexasHonda's Avatar
Relays are integrated in Relay Control Module (part of underhood fuse box).
Have you checked the stem switch? This could also cause intermittent on/off problem.
good luck
File Type: pdf
File Type: pdf
Old 06-16-2017, 09:48 AM
Received 8,584 Likes on 6,630 Posts
That sounds like a textbook Ballast issue to me... Exchange them from on side to another to rule it out.
How did you figure it was not the ballast ?
Old 07-08-2017, 05:48 AM
gftgrill's Avatar
Your best bet here is to get out a multimeter and test for voltages at the power connector. If you turn the switch on and the light is off, then use the multimeter to confirm that the ballast is receiving the correct voltage at the plug.
If the light is off and you have the correct power, your issue is not electrical, but rather a failure of the bulb, ballast, and/or ignitor. My experience says that a bad ballast will generally take out the bulb and ignitor with it and you'll have to replace all 3.
Has your light been turning pink/purple or is it always white/blue?
I'm assuming you have OEM parts and not cheap aftermarket chinese bulbs?
dP-
07-19-2017 09:01 AM
honda1405
06-07-2017 04:10 PM
Tucky512
04-19-2017 08:08 PM
Indy Mike
04-01-2017 11:14 AM
Dan Martin
TSX Frequently Asked Questions
08-15-2005 11:05 PM
Quick Reply: 2004 TSX HID - Is there a relay? Where?
