DIY- Remove Top Console Cover (also Replace Cup-holder)
Old 01-02-2011, 01:26 AM
haole kama'a-ina
737 Jock's Avatar
Perform Do-It-Yourself auto maintenance at your own risk. You can kill or injure someone or damage the car. Work or raise an auto only on a level, concrete floor. Do not go under any auto unless you are completely certain that it is secure. You and only you, are responsible for your work and safety.
Before removing the top console cover you must remove the shift knob and boot assembly. Go here first: DIY- Remove/Replace Shift Knob and Shift Indicator Light
Front and rear, left and right is ALWAYS related to the car itself, NOT how you are facing it:
LEFT is always the DRIVER side.
RIGHT is always the PASSENGER side.
Text relates to the picture below the text.
Tools and parts needed:
1. 10 mm wrench.
2. Plastic auto body prying tools (a few bucks at Harbor Freight). Plastic is less likely to damage or scratch anything.
3. Eye protection, face protection, gloves and protective clothes.
Plastic prying tools are about 15 cm long and look like this:
Warning; there is electrical wiring inside the console, including SRS Airbag wiring. Begin by disconnecting the negative battery cable:
With the shift knob and boot assembly previously removed, the console top cover can be removed. Begin by gently prying up the silver, left side console trim piece. Start at the rear and work forward. As it comes loose, rotate the rear upward and pull the front clips straight out to the rear:
Do the same on the right side, silver console trim piece:
Here is the silver trim removed, showing how the clips go into the console:
Open the console lid for clearance. Starting at the left side, gently pry to release the console top cover clips. Note the clip at the rear under the lid:
Do the same on the right side. Again, note the clip at the rear, under the lid:
The top cover is fairly tight against the lower front panel (seat heat and power outlet). Gently work it loose and lift it off:
If you need to replace the cup-holder, it simply unscrews from the bottom of the top cover:
Installation is the reverse of removal.
If you are accessing the console light wire, continue.
Go to "DIY- Replace Console Light, and Fix Short Console Light Wire"
dr427 (02-09-2013)
Old 01-02-2011, 03:14 AM
haole kama'a-ina
737 Jock's Avatar
Link: DIY- Replace Console Light and Fix Short Console Light Wire
Old 01-14-2013, 09:14 PM
SinCity's Avatar
Thanks!
Old 05-28-2013, 11:21 AM
genesis211's Avatar
Can anyone tell me how to remove the leather for replacement from the 2008 RDX console lid., The three screws don't do it.
Old 07-05-2013, 10:50 AM
SinCity's Avatar
+1
Old 06-09-2014, 01:59 AM
matttrue's Avatar
Did you ever find an answer to this? I need to replace mine.
Old 06-09-2014, 09:49 AM
haole kama'a-ina
737 Jock's Avatar
Console Armrest Cover Tearing/Delamination
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
wusty23jd
09-24-2015 11:41 AM
V12 Inspire
09-10-2015 04:46 PM
Quick Reply: DIY- Remove Top Console Cover (also Replace Cup-holder)
