ZDX Technical Service Bulletins (TSB'S)
Subscribe
Jun 7, 2011 | 02:26 PM
Follow these instructions.
1. Open this link
Click any model and then any trim levels
3. Open any one of the listings.
4. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
2010:
TSB 10-007: (2010 ZDX) Safety Recall: Front Passenger’s Airbag May Not Deploy Correctly
TSB 10-008: (2010 ZDX) Retractable Master Key Does Not Lock in Its Extended Position
TSB 10-012: (2010 ZDX) MID Displays CHECK BATTERY SENSOR With DTC B1192 Stored
TSB 10-013: (2010 ZDX) Audio and Navigation Systems Reboot by Themselves
TSB 10-028: 2011 Acura Paint Colors and Codes
TSB 10-042: (2010 ZDX) Different XM Presets Cannot Be Saved For Driver 1 and Driver 2; Alabama Navigation Defaults to California When Destination Is Entered.
TSB 10-051: 2011 ZDX TQI
2011:
TSB 11-019: (2012 ZDX) TQI and New Model Service Information
TSB 11-029: (2010-2011 ZDX) Front Inner Fender is Warped, Does not Fit Flush Against the Fender
TSB 11-032: (2011-2012 MDX, 2011-2012 TSX, 2012 ZDX) Rear Entertainment Restarts when the ignition is cycled
TSB 11-033: (2010-2011 MDX, 2010-2011 ZDX) MID Shows Battery Charge Low
2012:
TSB 12-007: (2010-2012 ZDX) Product Update: Software Update for Lock-Up Clutch Function
TSB 12-008: 2013 Acura Paint Codes
TSB 12-035: 2013 TQI Information
2013:
TSB 13-012: MIL Comes On With DTC P0339 and Possibly P0300 Through P0306 (2010-2012 ZDX
TSB 13-024: MIL Comes On With DTCs P0300 Thru P0306 (2013 MDX, 2013 TL SH-AWD, 2013 ZDX)
Reply 0
Mar 11, 2014 | 12:35 AM
bump
Reply 0
Jun 7, 2014 | 01:32 PM
Thank you, this will be helpful for me as I pick out a used ZDX.
Reply 0
Subscribe
