Wet Driver Side Floor Mat
Hello, ZDXers.
It seems I have water finding its way onto the driver side floor mat and floor carpet right below the left foot footrest (where your heel sits). I believe it's coming from above, under the dash, but (for the life of me), I cannot find a trace of water anywhere except the wet spot where I stated. Has anyone experienced this?
I was thinking it could be a clogged or disconnected sunroof drain, but that doesn't make sense as the floor mat is wet too, not just the carpet. If it was running down inside the A pillar, the carpet would be the only thing wet, right? Not the mat sitting on top.
Unfortunately, I discovered it today, and it was raining yesterday, so I guess I hose down cowl around the wiper area, wait and see, then sunroof and wait.
Thoughts..?
Thanks,
Thoughts..?
Thanks,
zdxsr (08-22-2024)
My initial thought is that it dripped down from above (underside of the dash or e-brake pedal assy.), but no traces of moisture from above are evident; my mats are OEM, and the rubber underside would not have allowed the water to wick up into the mat from the carpet.
Mystery solved. It was a partially clogged evaporator drain line. The water was backing up, then finding its way into the ducts under the seats (shown below).
I didn't focus on that drain initially, because I was seeing evaporator condensation draining after a drive, and I noticed the wet floor after a major rainstorm, which had me focusing on a sunroof drains, windshield seal, or the possibility of a bad body seam seal.
robpp (09-09-2024)
2. Inserted length of trimmer line up into the evaporator housing to unclog (water drained out).
3. Vacuumed out the remaining water and clog with a small clear tub attached to a wet dry vac.
4. Blew out the disconnected drain tube with the vac (blower side) using the same small tub mentioned.
I wonder what factors are involved that might contribute to that drain clogging (age, dusty environment, mold, dirt roads, etc.)? My car’s AC still leaves a puddle when I park, but curious whether some kind of preventive maintenance could be worth considering (dependent upon personal driving conditions)?
Yes. There are cleaning kits available, and I plan to use one to flush out any remaining debris. I definitely don't need to experience this again.
I typically address that drain in the spring as part of my oil change service and I use the $3 tool from Home Depot. It can readily be inserted into the drain line from below the vehicle. Hair snake
