Transfer Fluid
Old 09-28-2018, 08:46 AM
NDM
NDM's Avatar
Transfer Fluid
Hi
I am planning to change the transfer fluid so I would like to ask what grade and brand are you using.
Old 09-28-2018, 12:55 PM
dynodan's Avatar
Hypoid GL4/GL5 90W. The only fluid the shop manual doesn’t specify should be ‘Acura’ brand, so any quality/name-brand should likely suffice. But, I always leave that chore up to the dealer, and have trans./differential/transfer case all changed simultaneously. Going by what they charge for that job, if they used 5 star French cognac it would likely be cheaper.
Old 09-28-2018, 02:23 PM
NDM
NDM's Avatar
I am doing all three, transmission and differential are only one option (DW-1 and DPSF) to me, but I have read people using different types and brands of transfer fluid but l guess, like you said as long it is Hypoid GL4/GL5 Sae 90, it will be ok.
Old 09-28-2018, 02:54 PM
zdxsr's Avatar
Originally Posted by NDM
Hi
AMSOIL Severe Gear.
Old 09-28-2018, 03:16 PM
NDM
NDM's Avatar
Originally Posted by zdxsr
AMSOIL Severe Gear.
zdxsr
That will be 75W-90, Right?
Old 09-29-2018, 10:07 AM
zdxsr's Avatar
zdxsr
My bad, I actually used AMSOIL Manual Transmission & Transaxle Gear Lube 75W-90.
I believe the severe gear version is just as well suited, just designed for a more severe environment, but I would call AMSOIL to get the specifics.
NDM (09-29-2018)
nyse_19
04-09-2016 02:09 AM
john50
1G RDX DIY & FAQ
02-23-2014 08:10 PM
NCGB
1/2G MDX (2001-2013)
10-10-2009 01:43 PM
Quick Reply: Transfer Fluid
