What can be done to eliminate the rattling sound from the subwoofer? It was great for 4 years. Now with the volume around 23, it sounds horrible. It's not the subwoofer itself but more like what it's housed in.
Hello Kirkg811,
I assume the subwoofer is located in the same place as in the 2010 ZDX. It's located under the rear cargo area behind the right rear seat.
It's located beside the tool case (under rear cargo area on left). Did you try to store anything in that area? Perhaps the rattling is caused by a loose tool?
does anyone know what the procedure is to remove the subwoofer?
I just wanna pull it out and tighten everything up and add padding if necessary
Originally Posted by TitusR
Hello Kirkg811,
