Advance Struts Replacement
hello all!
Recently i noticed that my rear passenger strut started leaking so i need to replace it ASAP. Since this is a pricey strut, can i just replace the faulty one or is it recommendable to replace them in pair? 60k miles.
Thanks in advance!
Thanks in advance!
I just had to do it on my Caddy too.
Annoying!
does the ZDX have normal shocks(non-ids)?
Applies To: 2007-10 MDX - ALL with Active Damper System - Check the iN VIN status for eligibility
2010 ZDX - ALL with Active Damper System - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-020.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-020.PDF
TSB 16-021 - Warranty Extension: 2007–13 MDX and 2010–12 ZDX Front Active Damper
Applies To: 2007-13 MDX - ALL with Active Damper System - Check the iN VIN status for eligibility
2010-12 ZDX - ALL with Active Damper System - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-021.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-021.PDF
TSB 16-022 - Warranty Extension: 2007–10 MDX and 2010 ZDX Rear Active Damper (6 Months)
http://www.urvi.net/forumfiles/SB/B16-022.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-022.PDF
TSB 16-023 - Warranty Extension: 2007–13 MDX and 2010–12 ZDX Rear Active Damper
http://www.urvi.net/forumfiles/SB/B16-023.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-023.PDF
hmmmmm i could save a few bucks if i only buy one. but i think i will be replacing both since i'm thinking to sell the ZDX. and keep the one that's good for a future occasion. thanks for the suggestion.
Sounds good man, and why you selling? I would love to have a ZDX honestly.
I totally understand. My MDX also has the ADS shocks and they scare me as well. The good news however is that you can install non-ADS shocks and it won't affect anything except maybe a slightly softer ride for a fraction of the cost.
i will consider changing to non ADS if i keep the ZDX next time it happens.
Si_jeff
1/2G MDX (2001-2013)
Jun 5, 2016 01:54 AM
bsprinker
Jan 31, 2016 02:16 PM
