Zaino Z6 & Ron Jon Legend Wheels
I don't see why it wouldn't be safe to use on wheels .. they, in most cases, are clear coated like your paint is.
One thing I wouldn't do , and I wouldn't do it on my paint either . is use it to remove dust etc. Your wheels are the closest thing to the crud on the road and most likely to pick up stuff you will grind into the finish.
I don't think you'll get the protection you're looking for with the Z-6 though. IIRC it's just a gloss enhancer, no? I actually did Z-2 and that seemed to make the wheels much easier to clean for quite a while.
J.
J.
Just as long as you stay away from carnuba products, you'll be fine other wise it'll melt and then all the dirt will embed itself into it.
Actually there is nothing left of carnuba to "melt" once it has been applied and flashed ( dried ) and buffed... What happens with carnuba is it breaks down when exposed to sufficient heat .. 140 F or so .. where sealants are good for a lot more.
JByron
01-08-2016 09:49 PM
bshotts
08-30-2015 02:08 PM
