Zaino Z-PC Fusion swirl remover
Hey guys has anybody used this product for more than light minor swirls? I used it on my 05' TSX with the porter cable and white pad and it didn't do anything. Do you think using a orange or yellow pad with this product would help or is this just not a product to do more than minor swirls? For the record I use all Zaino products and Z-5 did not fill in the imperfections either after three coats with zfx. Any input would be great. Thanks
Selecting a pad/product combo can be quite difficult. BTW, what pads are you using? If LC or Erasures, try an orange pad with Z-PC or use a different abrasive polish. This is from an old thread . . .
Originally Posted by TOGWT
Zaino Z-PC Fusion will remove mild to moderate (1500-2000 grit) CAS= 4/10, swirls and scratches. My take on its abrasive level after initial use would put it between 3M SMR and Iz Paint Polish. And would add that once the diminishing abrasives break down it produces a 'burnishing' effect on the surface (similar to Menzerna P085RD Polish) producing a high gloss.
Just dial 1911
1 Post
Z-5pro barely fills anything from my experience when it comes to fine swirls.. All it does is darkens the apperance of the car. I did see a post at a car forum that someone put if I can remember 15 + coats of Z-5pro, and it did fill in some swirls.
I don't think I'll apply 15+ coats on my car. I think it's waste of product even though you have ZFX for multiple coats. One or 2 coats of Zaino is fine every few months, but if you're after a flawless look, you'll need to polish the defects off your paint.
You'll need to step up to maybe a yellow cutting pad, or maybe even a little more aggressive polish since ZPC is a light polish.
Just work ZPC a little longer and see if there's any improvment.
dainmezron
10-16-2015 06:56 PM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
