zaino masters needed
Old Aug 6, 2002 | 08:08 AM
black bullet's Avatar
I was wondering something. I now have 2 coats of zaino on my car and it's fantastic. Recently though, i was at a softball tournament and when I came back to my car i could see that someone must of rubbed their bat bag against the car . It's not even a scuff,but a light rub in the clear coat. The real ? is if i use my porter cable polisher to take it out, do I have to start all over again with the zaino polish lok, etc.
Old Aug 6, 2002 | 09:02 AM
NSXNEXT's Avatar
I'm assuming you'll use something like 3M Swirl Mark Remover to remove the mark. If that's the case, yes, the SMR will remove the Zaino, but it's not a big deal.
After you've removed the mark, wash the area with Dawn to remove the fillers in the SMR. Then you really only have to re-Zaino the affected area.
Don't worry, Dawn will not remove the Zaino around the area that wasn't buffed out.
Old Aug 6, 2002 | 12:23 PM
another ?. NSXNEXT, my car sits out side under a tree and gets alot of treesap. Before adding another coat of Zaino i would have to clay the finish first to get the sap off. Does claying take off all the other layers of zaino that I have on there already. If so it would seem that I am starting over everytime I would want to add a layer of Zaino.
Old Aug 6, 2002 | 12:35 PM
Homer2's Avatar
if you only have one layer - then, yes - claying will reduce/remove that. there are a lot of variables in the answer of course, pressure applied when claying, depth of layer, age of layer etc .
it is just one layer right . . .
if you were going to clay it, then do that - and then just apply more zaino - depending on age, use your Z1 also, or ZFX f you have it.
the z1 or ZFX are good, because in some areas, you may remove the zaino, and you want the next layer to bond . .
of course, you'll get a good idea of whether you did remove it, or how much, when you wash the car after claying . . .
check the water running action . . . still runnin off the car like it was afraid to be there? then thats good
Old Aug 6, 2002 | 01:45 PM
Thanks for the help NSXNEXT and Homer2
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
TLDude876
Dec 28, 2016 03:18 PM
milehightypes
Sep 10, 2015 12:07 PM
