What is buffer burn?
Old 05-16-2009, 01:09 PM
mklaudt's Avatar
So I can kind of imagine what this is, but just wanted to find out for sure what causes it and how I can prevent it. I've read about it in a number of posts, but just want to clarify. Thanks in advance.
Old 05-16-2009, 01:55 PM
The Detailer
Denzil's Avatar
It's a result of any combination of high RPM speed, inexperience, slow movement, friction and surface temperature of a rotary machine on a vehicle's paint.
Old 05-16-2009, 02:05 PM
mklaudt's Avatar
Thanks. That's what I suspected. Does it look like swirl marks?
Old 05-16-2009, 10:13 PM
Evil Mazda Driver
PortlandRL's Avatar
It looks like this. Fairly obvious on darker colored cars but I've seen it on white cars before.
Old 05-17-2009, 07:32 AM
DAiNiUS's Avatar
Is it possible to fix it without repainting or water sanding?
Old 05-17-2009, 09:25 AM
Former Sponsor
DetailedImage's Avatar
You can fix what you see in the above picture, which are also referred to as rotary holograms. These typically appear when you use a rotary buffer improperly (too fast, too aggressive of a polish or too aggressive of a pad combo). It is usually repaired by following up with a finer polish and pad combination along with safer speeds.
Buffer burn, when you actually burn through the clear coat or paint, cannot often be repaired without the use of paint.
As a general rule of thumb, if there's still clear coat left, you can repair it or improve it.
Hope this helps,
George
Old 05-17-2009, 09:48 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,425 Likes on 3,031 Posts
Random orbits help to prevent this?
Old 05-17-2009, 10:27 AM
Former Sponsor
exceldetail's Avatar
Yes, due to there dual axis rotation......Often times, RO's are used for the final polishing stage to avoid halograms.
calrow
05-03-2017 10:21 PM
knight rider
03-04-2016 08:59 AM
Thuneau
10-03-2015 04:19 PM
Quick Reply: What is buffer burn?
