wax off with detailer
so me and my friend washed our cars today and did 2 layers of wax. each time we waxed we would let the wax sit for about 5mins or so then proceed to wipe off with megs auto detailer.
it was really really easy to take off the wax and dint need to do much buffing(saved my arm), but i was wondering if we take off wax that way will the wax be less effective. i forgot what wax we used but it was curabana(says the was last for 6months) and we used megs quick auto detailer.
we learned this technique from a friend who does this technique on his BM. the wax looks really nice too, clean and shiny.
Former Sponsor
Boosty, basically what happens is when you dont provide any cure time with the nuba, your reactivating the solvents not yet evaporated. In turn, this redistributes along the surface, remixing with the nubas you just applied. If you can let the carrier solvents evaporate, it will leave the nubas left standing, a chance to harden and allow protection. 2 light apps a day or two (weather dependent) apart are much better protection.
Some folks like dual application back to back which allows for a more even, thorough level of protection.
The Old Grey Whistle Test
Wax Application – like most car care products Carnauba wax is designed to provide maximum results with minimum product application, most Carnauba waxes work well using the WOWO (wipe on wipe off) method while still slightly damp but not completely dry, generally apply a very thin layer, preferably with a distilled water primed foam applicator; allowing it to haze, then wiping off. I would suggest you do a swipe-test (swipe the surface with your finger, if the wax is still liquid wait for a while and repeat)
Allowing a Carnauba wax or Glaze to set-up for 45-60 minutes (see manufacturers instructions on specific products) is usually more than sufficient, as wax doesn’t form a molecular bond like a polymer does this will allow the solvents to outgas, which will be dependant upon ambient temperature / humidity)
A good technique is to buff the wax with a 100% cotton micro fibre cloth and then spritz the paintwork with cold distilled water and wipe down, this helps to set the wax and will add that little extra gloss. Carnauba wax provides better protection from bird / insect excrement than a polymer.
Former Sponsor
Originally Posted by bo0sty
so i should jsut do the regular wax on, wax off, buff to let the wax cure
thanks for all the replies
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
