Water Spot Remover now available, in 8oz!
Former Sponsor
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Now available at Exceldetail.com, Chemical Guys Water Spot Remover, 8oz! This is replacing the Danase Water Spot Remover, which is is manufactured for Danase by Chem Guys!
![](http://i14.photobucket.com/albums/a304/exceldetail/Chemical%20Guys/WaterSpotremover8oz.jpg)
"Watermarks are caused by mineral deposits in water that can etch in to your paint, especially when your vehicle is in direct sun. Remove the mineral deposits and light etchings used to be extremely difficult because it typically involves high speed buffing and cutting polishes. However technological break through have provided us with safer and simpler solutions. The Chemical Guys Water Spot Remover is a safe way to quickly remove those nasty looking watermarks. Spray the watermarks and then gently agitate the surface with a soft and clean microfiber towel. The marks should dissolve and remove with ease. Stop starring at those horrible looking watermarks and start enjoying a deep and glossy clear coat again with the Water Spot Remover. Also works wonders on glass!"
Former Sponsor
Oh without a doubt. It will remove it all.
Also when completed with spot removal, give the area a good wash to remove the chemicals, a quick polish and then apply your sealant.
Former Sponsor
Theres really no diluting, other then maybe using a water moistened sponge applicator to wipe in. 8oz is plenty to do an entire car with.....but then again it all depends on how severe the spots are. Naturally, it doesnt remove etching, as that is something which requires leveling. Etching is actually a crater, which has reduced the qty and effectiveness of your clear coat in those areas.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
