under hood cleaning??
Old Mar 10, 2003 | 02:44 PM
acuraman32cl's Avatar
Lone CL-P Owner
i was wondering what people here use to clean under the under (the black engine cover etc...) as of now i just get an old wet rag but at canadian tire yesterday i saw a plastic and vinyl restorer. does anyone use anything special?? thx.
Old Mar 10, 2003 | 07:01 PM
Nicky Pass's Avatar
Fuct in the hed!
I use steel wool on all of the metal hosing. I use Armoral wipes on all of the rubber and black plastic. Simple green gets rid of alot of crap too!
Old Mar 11, 2003 | 08:30 AM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
wipe clean...sometimes with Evergreen....then shine it up with vinyl clean/shine
Old Mar 11, 2003 | 10:23 AM
Zigried's Avatar
I wet it down first with a damp rag, then I use some simple green automotive cleaner.
Old Mar 12, 2003 | 01:16 PM
acur8ly's Avatar
I used the steam setting on the preasure washer at work till I got my CAI now I just wipe with a damp cloth
Old Mar 13, 2003 | 03:12 PM
Butter98's Avatar
Simple Green and Black Magic Tire Wet do the trick!
Old Mar 13, 2003 | 03:34 PM
Lone CL-P Owner
so like black magic on the engine cover or what? i would think the gel would heatup and catch on fire.
Old Mar 13, 2003 | 08:53 PM
chef chris's Avatar
Homeless
Amorall has a blue can of those wipey thingey's...cleans very well. just be careful on the printed lettering, stickers, etc.
Old Mar 15, 2003 | 10:45 AM
Butter98's Avatar
Yeah, Black Magic on the engine cover hoses, whatever. The Black Magic I use is in the spray bottle. Never seen the gel...
Old Mar 16, 2003 | 05:41 PM
ccshamrock2004's Avatar
Lucky Ole' Shamrock
Step1. is to cover any part in the engine bay that is exposed, i.e. exposed air intake, distributor cap, battery, ignition coil, and sensors.
Step2. when everything is covered, use a spray degreaser, (such as gunk brand), spray the degreaser in the engine bay liberally. let soak for 10-15 minutes. After around 5 minutes you can scrub any hard grime off, with a bristled brush.
Step3. after letting the degreaser dry for its recommended time, hose it down thoroughly and make sure you get all of the degreaser and grime hosed off.
Step4. let the water dry, it is important not to start the car up until the engine bay is completely dry. some may use a leaf blower to speed up this step.
Step5. now your engine bay is clean of filth. using a water based dressing, on rubber parts will make it look richer in color. it is vital that you use water based dressings because a silicon based dressing will deteriorate and can cause sensors to fail if sucked into the air filter.
Step6. the engine bay also has paint, using a good wax here can really set off the appearance of the "bay". don't use your best wax, just something that gets the job done.
Step7. the engine bay also has soe metal in it. using a nice metal polish on a nice rag will do, just rub it in and then buff out.
Old Mar 16, 2003 | 09:52 PM
Butter98's Avatar
Black Magic is water based, Armor All and such are not and will turn your hoses brown after time.
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
