Under the hood
Old Aug 12, 2013 | 12:05 PM
blkcou's Avatar
blkcou
Cool Under the hood
What should I use in the engine compartment to clean all the plastic covering. I would like it to look like new, not sure if armor all is good in this application because of the heat in this area.
Old Aug 12, 2013 | 10:24 PM
Jesstzn's Avatar
I use an APC like Awesome to clean it up. Apply it to a cold/cool engine and agitate then rinse. I will use a leaf blower to pre dry the a cloth to finish it off.
The Armoral type dressings work fine. Matter of fact as an experiment I used the Dollar Tree tire dressing on my Civic plastic etc close to a mont ago and it is holding up just fine and collects dust less than the "name" brands.
Old Aug 13, 2013 | 03:29 AM
06_TL's Avatar
I keep mine relatively clean but the first time I thoroughly cleaned the plastic under the hood I sprayed it down with some APC, agitated with several brushes, rinsed off and dried with a metro blaster and microfiber towels. I then used Sonus trim and motor kote to protect it and give it a satin dark finish. I would stay away from using armorall. From my experience, it leaves the area greasy which will attract dust. If armorall is the best you can do the. Make sure to wipe off any excess with microfiber towels.
Old Aug 14, 2013 | 05:59 PM
SUPERCAPRICORN's Avatar
Vinelex!
Old Aug 15, 2013 | 01:51 PM
siegs's Avatar
P21S Total Auto Wash All Purpose Cleaner &
303 Aerospace Protectant. Quick, easy and long lasting.
Old Oct 3, 2013 | 07:21 PM
dell12345's Avatar
6th Gear
CD2 engine detailer if you can find it.
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
dirleton
Sep 28, 2015 07:05 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
BookemDanole
Sep 11, 2015 04:53 PM
