Tuf Shine Twins......
Former Sponsor
.....now available!
The best of both worlds.....You know, or have probably heard about Tuf Shine Tire Sealant by now, and if you havent, well its probably due to the fact, your just not paying attention in here! An incredible Tire Care product is now matched up with the same companies Detail Spray.
Tire Sealant:
Perfect for autos, trucks, cycles, RV’s, trailers, ATV’s and more
Lasts for months & months & months ……
Withstands repeated high-pressure washings
Seals in factory lubricants and blocks out UV and ozone so tires stay pliable
Contains NO OILS or SILICONE that can cause dirt and dust to cling to tires
NO SLING OFF! This usually occurs with other “WET” look tire dressings
Anti-static. Since dust won’t cling to TUF Shine, you can now dust your tires!You control the shine. The more coats, the more shine
Spray Detailer:
Simple to use.
One EZ step cleans, shines and protects an average car in less than 15 minutes.
Water will bead on paint as if it was just waxed.
Formulated using high tech polymers.
Protects paint and clear coat finishes.
Perfect for black and dark colored finishes. Leaves no white haze or residue of any kind.
Won’t leave swirl marks when properly applied.
Anti-static. Will not attract dust.
Goes on easy and buffs dry in seconds. Like wiping off water, it’s that simple!
Use on paint, chrome, plastic, glass, fiberglass, metal and any other hard non-porous surface.
One product does all non-porous surfaces.
Pleasant fragrance.
Immediate results.
Adds high luster.
Enhances gloss for a "showroom" finish.
Not a replacement for wax, but will extend the time between waxing.
Lubricates the paint to prevent spider webbing and dry paint checking.
Apply with soft clean terrycloth or micro-fiber towels. Use one towel to apply and a second, dry towel to polish.
May be applied in direct sunlight without streaking when immediately wiped dry.
Towels can be machined washed after use.
6 to 10 applications with one 22 oz. bottle
Pictures are linked!!
Tire Sealant:
Spray Detailer:
Simple to use.
Pleasant fragrance.
Immediate results.
Adds high luster.
The Detailer
Yeah, the spray/quick detailer can be used to clean up lightly dirtied surfaces or between polishes to provide that extra bit of protection even though it's only temporary and usually short-lived.
Former Sponsor
Im glad I have nothing to do with it.......
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
