Tried CG Honey Dew Snow Foam and Dodo Supernatural Hybrid
CG Snow Foam Wash
- I was quietly and pleasantly surprised by this. I have used Pinnacle bodywork shampoo for YEARS. I mean YEARS... I have loved that thing for a long time (yes, me "love it long time" LOL). I didn't think anything would surpass it. Well. There's always room for change. Snow Foam was extremely sudsy and extremely slick. For the first time, I followed instructions on the quantity to use... 2 oz. Then a dab of ONR. Then water in my bucket. The suds were insane.
During the washing process, Pinnacle or DP Extreme Foam would always tend to lose some of their bubbles... especially as I use a thicker mitt... This time around, 1/2 way through the washing process, I took a pic of my bucket. There was a lot more foam in there. Minor thing to others maybe, but to me, since I'm used to seeing something everyday, this was a pleasant surprise.
I also noticed two other things that it had over Pinnacle. It was noticeably slicker. I would rub the bucket solution in my hands, and I've done this with my Pinn and DP ONR combo as well, and it's for sure slicker. During the wash, my mitt is also noticeably slicker on my paint. So that's always a good thing. The best thing I noticed though, is how it really did NOT detract from the beading process. What do I mean by this? Whenever I wash my other cars, after the initial rinse, it's obviously beading very intensely. But after a wash, I notice that there is a very slight reduction in beading, and starts to sheet a tad more. NOT AT ALL with Snow Foam. I wish I took a video before and after washing (during rinse) to show you the beading. I did take a quick pic though showing the bucket and the rinsing... this is all POST wash. I was already done. And look at my bucket foam too. In the pic, this is AFTER my washing... my wash Snow Foam bucket is on left, my ONR rinse bucket is on the right (yellow). For the price, you can't beat this. Snow Foam might now be the successor to Pinnacle. That says a lot for me.
PROS
- extra slick
- extra sudsy
- long lasting foam
- cheap
- good scent
- does NOT strip/remove ANY lsp, even nubas.
CONS
- not sure I can think of one... my its anonymity? It will be famous soon enough
Here's a pic with water being sprayed on it... took some dexterity holding a hose in one hand, DSLR camera in another. lol
Dodo Juice Supernatural Hybrid (SNH)
- I have not used this product since the one time last year and a half sometime. I didn't even remember how it LOOKED. lol. So after my wash of Tori, I decided since it had a coat of SN (the real original one), I said, why not try the hybrid again on it. What I IMMEDIATELY noticed was how much easier it was to apply than SN. It not only felt slicker as if I was applying Fuzion/Souveran, but you could SEE the traces of where you applied SNH. When comparing to SN, I could hardly see where I was applying, so making sure it was thin and evenly covered was a tad harder for SN. SNH made it super easy. Removal was also muchhhhh easier. Like removing Fuzion. Looks-wise, it looks like SN, but with slightly less flake pop. I would have thought that with it having a polymer, it would have helped amp up the flakes more? SN I love on Tori's silver moon paint, because it really boosts the flakes. So for SNH, maybe it was just the lighting, etc... but I just noticed slightly less. Will I use it again? Oh yes... I am a Supernatural fan. That's Dodo's best stuff by far.
PROS
- Fuzion-like in its application/removal
- I can actually SEE where I am applying it, even on silver paint.
- still has the famed Supernatural warm glow look to it
CONS
- dare I say slightly less flake pop?
- cost!!!
ok got some sunlight pics of Tori wearing her SNH today. This was after I came home from lunch, so there might be a thin coat of dust on her already, but I think for silver metallic paint, I'm impressed with SNH... not sure if I see much difference in sunlight compared to original SN. Upon further inspection, degree of flake pop seems to be the same...
Thanks for reading... hopefully some of you have used these products and can resonate with my opinions. Thanks.
PROS
- extra slick
- extra sudsy
- long lasting foam
- cheap
- good scent
CONS
PROS
CONS
- cost!!!
Keep'n it clean- Orlando
I tend to use the CG citrus wash on every wash, but I seem to be getting mixed info, is that wash supposed to only be used as a surface prep/stripper for pre-wax applications... or can I use it as my daily/weekly wash soap without it stripping off the carnuba and other waxes on the surface?
Which soap of CG's do you use most? citrus or the snow foam on a daily basis
My first Avatar....
<---open to any advice from the OP as well.
My first Avatar....
check thanks.... Ive been using a lot more the a few caps per 5 gallon buckets to get lots of suds and lubricity on the mit... I guess Ill have to call them direct and get a more appropriate wash for what I am using it for.... good news is I still see good water beeding and sheeting so I dont think its a good stripper as say dawn dish soap would be...
If you do call CG and find anything out please post it up.
The answer was the citrus wash WILL strip off the wax and products on the car. Where as the Honeydew or the extreme wash, or even the maxi-suds is designed for a daily and weekly wash without striping the wax.
I also informed them it would be nice to clarify a little more in the wash descriptions as all the marketing hoopla makes it extremely ambiguous as to what you're purchasing.
<---fml as my $70 carnuba and glazes are being stripped without me knowing.
My first Avatar....
Ok so I called CG's direct and asked them about my question above- Is the citrus wash supposed to be used as a stripper only or a daily/weekly wash.
I have to say....I'm more than a little pissed. Did they say that it strips no matter what the dilution rate? Thanks for checking into that!
I've used citrus wash and clear for a while and it seems to work ok as long as you are very strict with the "dosing". Sometimes I even lean on the side of a little less soap to make sure I don't strip any protection.
I've thought about bring the honeydew recently, though.
For honey dew, as I posted, it does not strip at all...of any sort. It's the first wash I've used that really had no degradation in beading. As for dosage, I just eyeballed it even...so I probably put wayy too much in there. But still, super slick, and no stripping. Love it.
My first Avatar....
Sorry for the delay bro... Been so busy this week. But as far as your question, I have both the citrus and the honeydew. The citrus I use only when I want to strip, which is essentially every two weeks. I love applying new and different LSPs (don't ask how many I have lol) as often as I can. So yes, citrus strips. Even on "daily" wash dosage, I found that it starts to make my paint lose its beading...so i know that it is stripping.
Fawkin CG have some REALLY bad marketing on the citrus!
x's 2
I could scream right now.
Lol why are you guys so sensitive about cgs marketing campaign?
My first Avatar....
This is why:
Seems like they are marketing a stripper as a wash/shampoo. If it is going to strip wax and sealants, then they should market it as a stripper. Seems pretty basic to me.
nonetheless. I just HAD to order a couple more shampoos to test.
btw...Thanks for the tip on the Menzerna Power Finish 2500 polish. That stuff is awesome! Best corrective polish I've used!
Citrus Based High-Performance total auto wash & gloss formulated to simply be the best wash& gloss at any price. The Best Naturally derived Citrus Hyper Shampoo and Gloss Enhancer.....Dilutes 1 to 4000 the highest concentration of premium wash soap in the world. (1 Cap Full) mixes with 5 gallons of water delivering the finest premium clean surface that shines. A citrus base, hyper-concentrated wash+gloss is the ultimate surface prep paintwork cleanser, shampoo and gloss enhancer in one. Ultra hyper concentrated citrus extracts break down dirt and grime while lubricating surfaces allowing debris to be gently rinsed off. Naturally derived Citrus extracts are formulated with the finest cleaning and glossing agents available today to deliver a 100% pure Citrus Cleaner free of artificial thickeners, colors or additives delivering the cleanest, streak free high gloss finish.
This is why:
My first Avatar....
Yep, LOVE it! I wish AutoGeek would put it on sale, I'd put some more on my shelf! I was also looking at the PO85RD Ultimate Finish UF-4500, a little less cut, a "1" as compared to a "2.5" in the Super Finish 4000. But, the same gloss factor as the Super Finish 4000. What do you think?
But gloss wise, it's hard to tell a diff between super finish. Both are stellar.
pttl (07-04-2012)
My first Avatar....
Had to bump this thread instead of making a new one:
Well it's official, I dislike the Chemical Guys car wash/shampoos that I've tried from them. I've been using BOTH the Honeydew, and their Glossworkz Shampoos. I won't even mention the Citrius Wash which is actually a stripper.
I don't know about anyone else but, it just seems like the CG shampoos have no lubricity when washing my car. The wash mitt feels like it drags across my car when washing. I even tried mixing in a small amount of ONR, as suggested by Jesstzn, and still no good.
I got out a bottle of Pinnacle XMT Shampoo and conditioner, that I had sitting on the shelf for a year....FANTASTIC lubricity! I had forgotten about this great little car wash. Now I feel like my wash mitt isn't just scraping across my paint when i wash.
I have a $20 Pinnacle gift certificate from Autogeek. Guess What I'll be buying.
Chapter Leader (Midwest Region)
If you like ONR, try Optimum Car Wash. I've heard nothing but good things about it.
I wish I had hose access so I can wash my car the regular way. My car would hate me from washing it too much
Edit: I fail at reading! I guess you found a good soap that you like. Good luck
-------Tim-------
Slightly off topic....sorry OP, but maybe you or another detailer could help me choose the best product to clean that black gunk around the trunk drains. This thread below says the CG-Citrus Wash and Gloss used in a specific mix ratio(read many diff ratio's)will take this away. Is there another product that will perform better? All input is greatly appreciated.
https://acurazine.com/forums/wash-wax-23/diy-cleaning-hidden-gunk-56k-fail-744104/
Thanks in Advance!
Thanks in Advance!
https://acurazine.com/forums/showthread.php?t=744104
Thanks in Advance!
Thanks in Advance!
For stubborn grime, I use ARO.
One of the major flaws of CG is their TERRIBLE marketing/product info sections. It's been nice to see all there stuff over at Autogeek because they have been able to sort through the mess and put down whats needs to be said. But since A LOT of their products accomplish the same thing, there is a lot of overlap.
-------Tim-------
I read in the thread that I quoted, that a certain ratio of the CG citrus wash and gloss would work. I also have read that many members didn't like that it wasn't as lubricating (of a car wash) as other products. I don't plan to use it every wash, but probably before waxing (as it is also a good stripper (of prior waxes)). ?
What is ARO?
Thanks for any/all help!
My first Avatar....
Pttl.... Sorry you don't like cg shampoos. Not sure why you have no lubricity with honeydew. I used it often and love it. Pretty slick for me. As for citrus, I use it as a regular wash sometimes, and it does strip sometimes, but usually only when I use a larger dosage. I do that when I want to apply a fresh lsp.
I did use the citrus wash as a stripper this past weekend....works great for that!
neuronbob
23
07-16-2019 10:48 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
