Tire gel!! No sling No Fling mess
i hate it after a nice 6 hours spent on your car it get ruined by a tire gel product like black magic tire gel and i for get the other,
i dont like tire spray because it gets everywhere.
foam is ok but dont lias as long.
I Just love gel because it looks alot more wet and last longer.
is there any over the counter tire gel that i can apply a heavy coat and not have it sling on my car????????? please help
i havent tried meguiars yet do they have anything?
even when i do apply light coats i still get fling on my car an its a ***** to get off with qd they have this product i see all the time called shining monkey but i perfer to get somthin over the counter and use it right away
now i have black magic tire gel which flings, megs nxt insane tire shine spray out of a spray can but it gets everywhere. I live in tennessee and its always windy or rain here.
i love the wet tire looks you know i mean really wet i have a thing for wet tires lol and shiny cars.
and ive used liquid spray like megs and some other products but it dont last long, and also dont even look wet at all lol only when u spray it.
The Old Grey Whistle Test
Tyre ‘Sling’As you drive the tyres rotate and the inertia can cause tyre dressing to ‘sling’. This can be caused by (a) applying the product to an improperly cleaned surface, to which it cannot adhere too. The preparation of the surface is the cause of this problem not the product (b) and / or an excess of product. Remedy- after the dressing has penetrated remove any excess.
This is often a problem with solvent-based silicone dressings (Dimethalsilicone or DMS) usually a clear greasy liquid, this type of oil they does not dry easily
Remedy- use a water-based product that cleans, restores and protects. Produces a temperature-resistant seal and a low-shine satin finish that is dust-resistant, that will not sling and it retards the fading effects of UV rays Petroleum-free, water-based formula is approved for use by tire manufacturers and is patented for its superior long-term protective properties and wash- and weather-resistant features that prevent streaking and loss of UV protection.
Alternative product - 1Z (Einszett) Vinyl Rubber Care and Protectant or Swisswax Pneu, water based and provides UV protection and a matte satin finishor
Application
•Apply tyre dressing to a clean dry surface, adding small amounts of product as needed
•Using a suitable foam applicator apply a thin coating
•Don't add too much, just enough to keep the foam moist
•Once you’ve applied a dressing to all four tyres, remove any excess with a dry applicator or towel
Application
Clean tires with an APC ( Belive it or not Awesome APC from the Dollar Tree store works great ) The Optimum Tire Gel dilluted 50/50 and applied with a cheapie kitchen sponge.
A lot of times also sling ic caused from over application and the product is in the tread in the tire edges. Like a lot of things in detailing .. lots isn't better.
TOGWT has very good info in his post about "why"
Matt
Application
Application
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
How long do you let the gel sit before driving? I let mine sit for a few hours before even moving the car
obviously you havent used the megs insane tire spray it come out a spray can, Like spray paint therefore if you sprayed it on a towel it would pretty much eat up a quarter of a can just to do one tire.
its about $9 a bottle.
how about you go try it out and give me some good feedback instead of trying to be a smart ass.
I use some flat dressing and a cheapo foam applicator. No mess, ever.
(Mid-Atlantic)
(Mid-Atlantic)
AZ Community Team
Received 7,771 Likes
For the two sniping each other - knock it off. Not necessary; not helpful.
I don't like Black Magic. It leaves a residue/build up. It does last, but I don't like the build up.
I've been using Meg's Hot Shine. Gel first, but have the spray at the moment. I don't have a slinging problem and think it is primarily about using just a little an working in well. IOW - don't over apply your tire dressing.
(Mid-Atlantic)
(Mid-Atlantic)
thanx for the tip patrick!! also i tried looking through your site do u sell grit guards for 5 gallon bucket i couldnt find anything/ /
(Mid-Atlantic)
(Mid-Atlantic)
Former Sponsor
1 Post
Here ya go.............Last one in stock also!
Glad I got my order for two in over the weekend. How long does it take you to refill your stock usually?
