Thoughts on Meguiars DA power system
Hello everyone I have been thinking about getting a Meguiar's power system buffer to attack those annoying swirls I have going on, has anyone ever used one at all? let me know what yall think. Thank you
the problem with using a drill to activate the DA heads, is that YOU will have an inconsistent trigger finger.
that is, your trigger finger cannot maintain a certain RPM for prolong periods of time. which will then provide inconsistent results. not to mention, the DA head isnt random...but a pattern.
real machine polishers have a RPM dial that you can set it to, providing consistent RPM's !!!! making for consistent results. it's why its hard to mess up paint with the trusty PC7424XP
mattcl-s (10-26-2015)
What Justn said.
Finger controlled trigger means varying rotational speeds. I would use this for buffing headlights. I wouldn't use it anywhere else on the car.
Come over in the spring with a wad of cash and I'll help you out.
justnspace (10-26-2015)
I might have to buy that porter cable in the spring. I was kind of broken hearted yesterday after I did a clay bar and hand wax last night, then after I got it some good lighting I realized how bad the swirls are on it. I am no professional but at least it tried.
justnspace (10-29-2015)
To follow up to Justin - you don't want to cheap out on this part of the deal. You (likely) spent a fair amount of cash on your car - is it worth trying to save a couple hundred dollars now when you would be putting the car's finish at risk?
A quality DA (PC or Griots or Flex or Rupes etc etc) will make it almost *impossible* to damage the finish of your car and you will be able to use it for years to come - likely on other cars you buy. Get the right gear - you'll be very happy you did.
mattcl-s (10-29-2015)
A cheaper route if you wanted to see if detailing is your thing is to pick up a Harbor Freight DA (use their 20% off coupon) but replace the backing plate and pads (can be found on Autogeek). I've heard people have really good luck using it as a beginner DA, only downfall is the backing plate and pads suck.
The Griot system is a great safe way to correct paint defects and maintain your finish. I learned to wheel paint with a wool pad on an angle grinder 30 years ago. The new foam pads (and the newer microfiber pads from Griot and others) and DA's make the task enjoyable and rewarding for an enthusiast. Like many, I have a shelf full of products and I enjoy experimenting and finding the right combinations for a particular car. Purchase a high quality DA and you will be amazed at the talent you uncover in your own garage.
mattcl-s (11-17-2015)
Just my two cents... I have the Meguiars DA drill attachment. It's too small, and justnspace is right about inconsistent trigger finger. I used it once for cutting/polishing, glaze, and wax... Took me all day and shit my finger hurt.
thegipper
10-12-2015 03:55 PM
