TAR on my bumper
Old Jun 5, 2005 | 09:37 PM
Mark307's Avatar
TAR on my bumper
So some tar got on my bumper and dripped a little. I tried to use tar remover but looks like it stained. I then tried to clay it,compound it, polish it out with an orbital(not a PC) but it wont come out. So what would be the next thing to try?
Old Jun 5, 2005 | 09:56 PM
2003TLSNKC's Avatar
Depends on how much tar...but when i get some on my car Megs Cleaner/Wax has always done the trick and taken it off.
Old Jun 6, 2005 | 08:04 AM
Moodist's Avatar
I would think clay is the only thing that can get that out. Did you try applying a little more pressure or claying for a bit longer?
Old Jun 6, 2005 | 08:13 AM
Mark307's Avatar
I didnt rub too hard, maybe I'll use the tar remover as a lubricant with the clay bar and put a little elbow into it. Thanks
Old Jun 6, 2005 | 10:04 AM
TOGWT's Avatar
The Old Grey Whistle Test
Tar (Asphalt) Removal:
The reasoning for the use of solvents for the removal of road asphalt (tar) is that it dissolves it as a means of removal as opposed to rubbing it. Asphalt (tar) is very sticky and its presence on your paint means that harder particulate matter (dirt/grit) has also stuck to it. By agitating or rubbing the dirt/grit that is contained with the asphalt will cause surface marring or possibly scratching, dissolution alleviates any potential damage.
A solvent (Stoner™ Tarminator) can also dissolve a variety of oil and petroleum based products. It's safe to use on all types of paint, plastics, synthetic fibres, carpet and upholstery. If used on vehicle paintwork re-apply a protect rant after use.
Other uses - it will dissolve chewing gum and adhesives. Use to de-tar wheel rims after cleaning, will also remove shoe scuffmarks from vinyl trim, and can be used to remove tree sap or fuel stains from paint surfaces.
JonM
Old Jun 6, 2005 | 02:40 PM
JGsTL-S's Avatar
I might get flamed for this but I used charcoal lighter outta the garage over the weekend on some tar spots I had....worked awesome! just went behind it with soap and water, polished it up and good as new. cheap too!
quanaman
Jan 9, 2023 07:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
