Steam engine cleaning
I have not washed my enginer for about 2 yrs and getting really dusty underhood. I dont wash with regular spray and considering to take it to steam cleaning service. Is it safe? has anybody done it to the car? Thanks1
wow- actual steam cleaning would be the best method- less water splashing around sensative electronics
But most of us just spray wd40 on anything we can reach and simple green in a spray bottle or Gunk engine cleaner (citrus smell is nicer) or even some spray tire cleaners work on paint without issue
Use gentle spray rinse with clean water
there is bound to be a thread on engine cleaning in gen2 or 3, try internet search of the site by typing engine cleaning +acurazine.com
that works better than azine search in many cases
protect the alt and ps-brake master with plastic bags
dont spray into them or you will need to replace fluid-flush which you should do anyway- brake fluid every year, others every 3/60
If you like spotless steam should do it
Engine Compartment Steam Cleaning / Power Washing:
Most engines are rarely so encrusted with automotive residues and dirt that normal, low-pressure degreasing methods fail to provide proper, efficient cleaning. High-pressure engine water / steam cleaning are unnecessary and should be restricted to extreme cleaning jobs, such as commercial trucks, off-road vehicles, etc.
The engine compartment is designed to resist water ingress; it is not waterproof / watertight. Rain or water splashed up into the engine is at very low pressure, very different from a pressurised hose or steam
High-pressure steam cleaning can force solutions into the engine harness sheath and associated cables, causing unusual problems that would not have occurred otherwise. Once steam is applied to a cold metal surface it condenses and becomes water that may be in a place that it cannot be easily removed from.
Modern vehicle engine harness multi-plugs and related sealing measures are not designed for the discharge velocity and force of typical commercial steam cleaning units. Further, cleaning solutions with the high-pressure discharge can leave conductive and often corrosive residues deep within the harness and cables.
Protection of Electrical Components
The most important electrical components are sealed ‘water resistant’, that is to say against low pressure, water splashing encountered in the course of daily driving conditions. As long as you avoid directing a strong stream of water (or a pressure washer at close range) directly into these components, you will be fine.
You need to cover various parts prior to using any cleaning products, sprays (water deterrent, formula 40(WD-40)) or water.
• Alternator
• Alarm Housing
• Intercooler
• Battery terminals (if not covered already)
• Induction kit cone (if you have one)
• Coil packs
• Electronic control units (ECU)
• On-Board Diagnostics (OBD) port
• Air intake systems (exposed air filters) can be covered with plastic wrap and a rubber band
Notes:
1. This is not an exhaustive list, nor is it marquee specific, if in doubt use a water repellent (WD-40) and exercise common sense
2. Tin foil is a better alternative to using cling-film for the alternator, alarm housing etc as it is easier to mould and has greater protection properties. I suggest you use a plastic bag for the induction kit and just wrap it tight over the end to stop any water ingress.
3. For the intercooler the best way to cover is to get a flat sheet of cardboard and just cut it to size so it fits and covers the fins. Cardboard will normally protect the fins for the duration of the washing. It will get soaked so discard after the wash.
An extract from one of a series of unbiased Detailing Technical Papers, a library of educational materials that has become the #1 reference for car care on the Internet
Chances are you'll learn something about detailing if you read any of these; although these articles will not improve your detailing skills, lead to a successful business or change your life. Applying what you learn from it, however, will. That's where your commitment comes in - you need to make a commitment to yourself right now that you will take action on what you learn.
• Alternator
• Alarm Housing
• Intercooler
• Coil packs
Notes:
© TOGWT ™ Ltd Copyright 2002-2010, all rights reserved
ok seems like first 01tl suggesting steam clean and also ordinary stream jet is OK.
by reading the second post from TOG, steam cleaning seems seriously discouraged and low pressure regular hose watering is better than high pressure steam. I am confused.
Car forums are all about people's experience / knowledge.
Focusing on one person’s methodologies or the products they use will seriously limit your detailing experience and knowledge. Most importantly - choose carefully whose advice you listen to, and more importantly what advice you act upon. The misinformation and myths that are so prevalent in the detail industry is the reason that detailers need to do research on their own.
I would strongly suggest that you verify any information that I or anyone else shares with you.
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
