Souveran Paste wax
Souveran Paste wax
Just got my order today with the stuff I am going to detail my car with. For the last 11 months I have been using NXT car wash and then NXT 2.0 wax. My plan for this weekend, if it doesn't rain is to wash it with Wolfgang auto bathe. Next clay it with the Mother's clay kit I have. Then apply Klasse AIO and Klasse sealant. Once the sealant sets I was going to use Souveran paste wax. After receiving my order I noticed the Souveran paste is recommended for dark colored vehicles. My TL is Palladium Metallic, so now I am wondering if this wax will look good on a lighter color like this. I don't expect it to have the depth it would on a black vehicle but I'm hoping it will still look decent. Anyone have experience using this wax on a silver vehicle?
Needs more Lemon Pledge
After the Klasse twins you may not want to add anything!
You using a PC or doing the AIO/SG by hand?
U are buying all these quality products and then applying them by hand is just a waste of money. A DA polisher is very easy to use and even for a beginner u will still achieve great results.
A suggestion for the Klasse, esp the SG:
Once you apply it VERY thin and let it dry (the time it takes to apply it to the next panel), when you go back to buff the previous panel have a small spray bottle with a little SG and water on hand. Shake it up and give the panel ONE small spritz (two for a large area like hood) if you find the buffing off to be too difficult.
The SG is pretty tough to remove by hand (takes a lot of work) and this makes it infinitely easier.
Ask me how I know.
Now, I put a MF bonnet on a pad on the PC and buff all I want! No pain, no numb fingers/hands/shoulders.
Also, TAKE PICS!
We love them.
Would love to hear/see how the Souveran turns out on top of the SG.
Nonsense. It can be done. The PC will make it easier, but Klasse and wax have both been applied and removed many times by people without a PC.
Ask me how I know.
Also, TAKE PICS!
We love them.
Ask me how I know.
Ask me how I know.
Souveran Paste looks best on dark colored vehicles, but will still look great on lighter colors too. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Klasse High Gloss Sealant Glaze, when applied correctly, will wipe off effortlessly. It can be a little tricky to use, and if it is hard to remove, that generally means you either applied too much product or didn't let it haze long enough.
Apply it extremely thin to a highly polished surface out of direct sunlight on a cool panel, let it sit for about an hour, and wipe off should be a breeze. But like others have said, if you have any trouble removing the product, use a couple sprays of water or a quick detailer to aid in the removal process.
Before applying the Souveran Paste Wax, let the Klasse Sealant Glaze cure for at least 12 hours.
I'm not a big fan of buffing off dried wax/sealant with a PC .. too big a chance of dry buffing and also one little piece of grit gets under the cloth/bonnet and its disaster swirls. Trust me I know.
As for applying the SG. Apply very thin, I initially mist a yellow foam applicator with distilled water then add a few squirts of SG from one of those 2 oz travel spray bottles. This primes the pad.
Do 2 panels then go back and remove the first ... do one .. remove one.
When removing SG I use a soft quality M/F and I fold inin 1/4 and then mist the face of the towel with distilled water and remove the SG. Might take a couple mists on the towel per panel.
Always remove in straight lines in the direction the air flows over the car where you can. Never remove in a circular motion. Always use the towel flat .. never scrunched up. Removal is very easy this way.
SG as with any LSP is dependent on surface prep. If you aren't investing in a PC at least add a paint cleaner to the program to remove the oxidization. ColorX is a good low $$ OTC one. Use it after claying.
Thanks for the info and tips, I appreciate it. Looks like Sunday and Monday should be when I do this since it is not supposed to rain either day. To bad my house doesn't have a garage, could have done this today. Pretty excited to see how the car comes out looking when I am all done.
Good luck!
Lot's of good advice here for the AIO/SG application and removal.
FTR, AIO/SG topped with Collinite 845IW is the bulletproof combo I use in Arizona in the summer. Beads like mad with good gloss/depth.
I need to strip the BF off the car and get the SG on it soon... We are near 100 degrees already.
Bent = #1
Klasse All In One Polish will remove oxidation, minor swirls, old wax, and other surface blemishes
AIO is for all cars .. old & new if they need a cleaner. If your going to polish the car with a PC and polishes then the AIO step for that purpose isn't needed but can be used after polishing to clean & prep the surface for the sealant.
Bent = #1
Klasse AIO is a chemical cleaner and the only swirls it will remove is if they are in the oxidized layer.
Got a severe case of strep throat last weekend and was finally feeling good enough to get this started today. Got the wash, clay, Klasse AIO and Klasse SG done in 4.5 hours (not to bad for doing it all by hand and still not feeling great.) Let the SG set for about an hour like Nick@AutoGeek suggested and it came right off with a MF towel. Car looks great now, can't wait to see how it looks once I apply the Souveran wax in the morning.
Took pics when I got done today and will take some tomorrow. Much harder to tell from a picture of a silver car than a darker colored car how good it actually looks.
Car was looking good this morning, but after the Souveran it looks incredible
I really wasn't expecting it to come out as good as it did since it's silver, but definitely a huge difference from before I started this morning until now. Just waiting for the sunlight to get a bit better where the car is parked and then I can get pics. Not sure if they will do it justice, but I'm definitely a fan of Souveran now.
Pics definitely do not show off how good it looks. The metallic in the paint isn't visible like it is in person...
![](http://i1100.photobucket.com/albums/g410/blkhwkz/Car%20after%20detailing/IMG_1012.jpg)
![](http://i1100.photobucket.com/albums/g410/blkhwkz/Car%20after%20detailing/IMG_1013.jpg)
![](http://i1100.photobucket.com/albums/g410/blkhwkz/Car%20after%20detailing/IMG_1015.jpg)
Correct me if I'm wrong, but I don't think an orbital is necessary for wax (except to save time and energy). I think an orbital is only needed for polishers where it needs to be broken down.
Hey, I use the PC for the SG, too!
A DA Polisher with a soft finishing pad applies a much more even, uniform coat of wax when compared to applying it by hand.
In addition another $100 output is tough to justify just for small areas.
Outside of the energy part I don't even find it saves time if you have to stop .. put down the PC .. wax the small area .. pick up the PC etc etc etc I still do all the application by hand. I have a second PC with a 4" pad and I tried that for tha smaller areas but again .. switch PCs .. and the smaller one still doesn't get ALL the small areas.
emailnatec
29
09-28-2018 04:27 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
