Roof Trim Discoloration
is that where you put your hand to get out of the car?
it almost looks like oil spots or something like that.
I would say try claying it, then try putting some good wax or polish on it and remove it quickly to see what happens.
that is a weird marking
If using a vinyl or rubber cleaner does not work, a product called forever black works great on stained and faded trim. Forever black is a dye based product so it will last vs just using protectant which will eventually go away.
Check out this from Exceldetail.com:
http://www.prestostore.com/cgi-bin/s...5599&pd=294730
This is actually a dye, that is permanent. I would think it would cover up those spots if they are still present after a good throrough cleaning.
Thanks again for everyones suggestions.
Originally Posted by Hawhyen51
I would suggest using a cleaner like this one and then follow up with a rubber/vinyl protectant.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
