Rim cleaning product advice!
Hey guys,
I need to get a decent rim cleaner for my 07 TSX (OEM RIMS). The only thing is, I don't have a hose readily accessible, so I have to rely soley on my 1 gallon mister/sprayer unless I go to the local coin OP. Since my car hasn't been too dirty lately, I've just been using the ONR to clean the rims. It does a good job, but I'm thinking that I should probably be using a dedicated rim cleaner - or am I totally wrong? I guess my question is, will the ONR clean SUPER dirty rims and brake dust?
Lastly, if I were to use something like a rim cleaner, would the 1-gallon mister/sprayer rinse the rims good enough?
Thanks much!
Jeff
Thanks much!
Jeff
What I have done in the past when my wheels got ridiculously dirty...which doesn't happen very often.
I pre-treated with ONRW to break up the dirt.
Let it sit about 10 minutes.
Then sprayed a little wheel cleaner for 30 seconds and then started washing with ONRW and sponge.
Anyways...that's what I did and worked great.
Sprayer doesn't have enough "power" to clean your rims for you.
You need to let the chemicals loosen the dirt to a point where you are not scrubbing the dirt off.
Let the product do the work.
On a rim cleaner , I think your totally wrong ... I never use a rim cleaner on my wheels. The only time they are necessary is if you neglect your wheels and regular car wash soap won't remove the dirt.
A rim cleaner is going to remove any protection you have on the wheels in short order. And some can be harsh on the clearcoat.
Wash often with the tail end of your wash solution and use a dedicated mitt for the wheels.
The Detailer
I like to use the Chemical Guys Sticky Wheel Gel. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
However, my wheels are pretty well maintained so I use the Chemical Guys Premium Blue wheel cleaner instead which is for maintenance-type washes.
Matt
Former Sponsor
Most wheel cleaners contain biodegradeable products which are totally harmless to CC'd wheels WHEN USED AS DIRECTED.....
Never use on hot wheels, avoid using in direct sun (when possible), never let product dry, pretreat with water to dilute wheel cleaner, rinse thoroughly.
merc009
10-03-2015 12:59 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
