Removing permanent marker from paint...
Wasn't there a thread about this about a week ago?
https://acurazine.com/forums/showthr...ight=permanent
Damn CG, don't you have work to do?
Originally Posted by lokman
Was just about to suggest that...
See post# 88
Originally Posted by jiggaman
My buddies Mini Cooper was tagged up with perm. markers. ANybody know what the best way to remove that stuff is?
Rubbing alcohol should take it right off. Use it at full strength, it wont harm your paint. If you dont want to try that then you can use a light poilsh to do the trick. I have a test panel that is a trunk lid off of a red Accord and I write on it all the time with a sharpie so I can remember what I put on it and when. I use rubbing alcohol most of the time to remove it when I start over. Just be sure to rewax the area as the alcohol will strip any wax.
Originally Posted by DEI99662
And btw, did you know you can post the link directly to that post?
Right click on the number of the post for the URL.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
