Red 05 Viper. Heavily Modified. Perfected by TSC17!
2012 SH-AWD / Advanced
I received a call from the owner a few weeks ago about his 05 Viper. He said that it was in pretty good condition, but wanted me work on it and "take it over the top".
He stopped by so I can inspect it and come up with a plan, and I was really impressed with this vehicle. He has done a trendous amount of tasteful modifications to this car, so my plan was to perform a high level detail that would showcase the pure beauty of the Viper. Red done right is a spectacular color, and the owner agreed that we achieved a whole new level of gloss and depth when it was finished.
As for the car, he's put in different pistons, cams, heads, and is running a direct-injected 300 shot of nitrous (among other mods). The nitrous setup has plenty of redundancies and fail-safes to keep the motor intact. He has done the mods properly! Right now it puts out about 650hp on the motor only, and is running just under 1000hp with nitrous. He's taking it this weekend (via trailer) to do some more dyno tuning as he wants to break the 1000hp mark and have it on paper. This car exudes testosterone!
The owner was an awesome guy, and we had a great time just sitting around and bench racing.
Enjoy the photos...there are a lot of them!
Process:
Wash
Clean wheels and wheel wells with Megs APC+
Clay body and glass to remove embedded contaminants (surface was actually pretty clean)
Wash to remove remnants and residue from claying process
Dry with Blaster Sidekick blow dryer
IPA (Isopropyl Alcohol) wipedown
Tape off graphics and other trim
Interior:
Vacuum
Clean all surfaces with Woolite/water solution. The interior looked pretty clean, but since it's a convertible I was able to remove a lot of dirt!
Treat all vinyl and plastic with Optimum Protectant Plus
Treat all leather with Zaino Z-10
Polish metal and CF trim with Klasse All-In-One
Clean gauges and controls with Megs Interior Detailer
Polish Nitrous bottles with Klasse All-In-One
Clean inner trunk lid and jambs with Optimum No Rinse
Windows cleaned with Stoner's Invisible Glass
Polishing:
Menzerna SIP with orange pads on heavier defects
Menzerna SIP with white pads on lighter defects
Menzerna PO85RD with red pad for final burnishing stage
Protection:
Optimum Opti-Seal sealant for long term durability
LSP:
P21S 100% wax applied by hand
Tires dressed with Sonus Tire Gel
Wheel wells dressed with Megs Trim Detailer
Wheels polished/sealed with Klasse All-In-One
Engine bay cleaned with Optimum No Rinse
Exhaust tips cleaned/polished with Klasse All-In-One and 0000 steel wool
Tools used:
Makita 9227c rotary polisher
Lots of Eurow shag MF towels!
Canon Rebel XSi with 18/55mm lense.
First up was the interior.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1768.jpg)
I made sure to clean all the areas on and around the Nitrous mechanisms
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1770.jpg)
Polishing the bottles with Klasse.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1772.jpg)
The trunk lid area had a bit of dirt and grime built up on it
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1774.jpg)
But it cleaned up nicely with Optimum No Rinse
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1775.jpg)
Even the underside of the trunk lid was polished
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1776.jpg)
Chrome and the CF trim was polished with Klasse
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1780.jpg)
Leather was treated with Zanio Z-10. It provides a great finish, and smells nice too.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1784.jpg)
I just thought these were cool shots, so I included them as well:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1782.jpg)
Process:
Wash
Interior:
Vacuum
Polishing:
Protection:
LSP:
Tools used:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1778.jpg)
The wheels were just done a week ago...powdercoated and finished. But as you can see, they already built up a bit of grime that is being washed away with Megs APC+
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1793.jpg)
After wash #1
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1794.jpg)
Some before shots. The car had light swirling all over it, and more deep scratches than I originally thought.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1756.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1753.jpg)
Even the tail lights were swirled up pretty badly
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1752.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1754.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1755.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1765.jpg)
After wash #1
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1757.jpg)
All of the graphics needed to be taped up to protect the edges...
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1798.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1797.jpg)
Here's a nice trick for convertible tops...use a fitted sheet to cover it and protect it from polish sling and dust. Tuck it down in the back area and close the trunk lid/cover to protect dust from getting down inside.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1799.jpg)
When polishing the vents, I had to tape up each one. I'd polish one, then remove the tape on the next vent and polish it, etc, etc. Very time consuming, but I'd rather take the extra time than risk damaging paint! In these tight areas (a lot on this car), I used the 4" spot buff pads.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1803.jpg)
Tail light before polishing. I used a 4" pad and SIP
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1804.jpg)
After polishing:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1805.jpg)
Yours truly in the final polishing/burnishing stage using PO85RD and an ultrasoft red pad.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1807.jpg)
The engine was already pretty clean, so all it required was an ONR wipedown. To protect it from polish dust from the hood vents, I covered the engine in towels before doing any work on it.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1814.jpg)
Not your average Viper motor!
After polishing:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1815.jpg)
And now for after shots:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1820.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1836.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1834.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1822.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1828.jpg)
The sun was at a pretty low angle in the late day sky, so this is the best I could come up with for "after" sun shots:
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1843.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1842.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1841.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1844.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1851.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1869.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1886.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1890.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1899.jpg)
The owner stopped by late in the day on his equally trick Ducati 1098! I know motorcycles more than I do cars (I have built several magazine project bikes), and I have to say that this one is a special example.
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1846.jpg)
![](http://i54.photobucket.com/albums/g95/tsc17/IMG_1850.jpg)
Thanks for checking it out!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Wow, great work. Beautiful car and bike *jealous*
Received 6,470 Likes
All I can say is WOW !!!
Everybody...thank you very much! Needless to say, the car was drawing a bit of attention while it was at my house. It's definitely not a car for an introvert!
Denzil...thanks for the props on the pics. I thought a few of them turned out really well, and obviously you agree!
you are the f'n man...love the shots of the car and that is one nice bike...i need to check this section out more...learn alot from reading this post on how to make my car shiny...i wish my SMR looked like that...
Thanks. Definitely get by more often...lots of good info in here.
Acura604
20
08-05-2017 12:55 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
ExcelerateRep
10-14-2015 08:20 AM
