Question on Using Glaze or Similar with Duragloss
Over Caffeinated
I currently have Duragloss 105 over the 601 paint bonding product. I like the idea of using a sealant and hope to get about 6 months of life out of a 105 application.
After doing some reading, it seems that the 'depth' of the sealant might be improved through the use of an additional polishing agent.
I now have a PC 7424 and will be going over my car to remove spider webbing, etc. My assumption is this will remove the 105 and I will need to reapply.
Questions:
1) Is some kind of glazing product compatible with the DG 105/601 products?
2) My primary concern is long life over ultimate looks. Therefore I would want to have the glaze under the 105 finish coat. Is that possible or are glazing compounds last coat only type products?
3) Assuming #2 is possible, what sequence would be followed? 601/glaze/105? Glaze/601/105?
4) Any recommended glazing products? (Please, no Holy wars).
Any thoughts, suggestion or recommendations are appreciated!
Thanks,
Steve
Questions:
Thanks,
Steve
if you have a machine now, you dont need glazes....glazes are usually used to cover up in lue of hard work...your machine with the correct pads and product will remove the spiderwebbing....now if you want to use the danase wet glaze thats a different story as its not like a traditional glaze....its more of a gloss enhancer....
and yes, once you wip out the machine, you will be removing any product you previously applied...unless your using the machine to add layers of your lsp....but any polish is going to polish off your original lsp...
Over Caffeinated
Former Sponsor
Sealants and waxes do little more then protect that clarity. They can enhance reflection and gloss (to a degree).
105 supercedes 111, as in it a newer product, but 105 has cleaners in it. 111 is more of a pure sealant as it does not contain any cleaners.
Glazes, on the other hand, are a marvel mystery to me. Other then filling, Im not sure how they stimulate the appearance.
Over Caffeinated
Depth actually comes from the polishing stages. This is why so many people are amazed at the changes that occur after purchasing and using a PC. They return the clarity to the paint by removing any light disturbing issues such as swirls and oxidation, which detract from clarity, and rob the owners/onlookers visual perception.
Thanks for the info!
Steve
