Probable Acura Bra Damage
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I have a 2006 Anthracite Metallic TL and recently moved across the country. I usually put the bra on during moves (in the military, so it happens relatively frequently) with no issues. I had the bra on roughly 2 weeks which is normal, and had washed/waxed the car prior to the move.
Once I got to my new location and took off the bra, I noticed some type of damage to the paint on the hood...my guess is that some water with some type of chemical/contaminant got into the bra and sat there causing the issue.
My question is, what are my options? I'd like to take care of it myself and have used clay bars and some Meguiars 205 level stuff before, and have done research on a DA polisher. Or is this something I can't touch?
I have tried to just clean the vehicle and also applied the M205 with no change.
Thanks!
Thanks!
2016 E350 Sport
I would wash the car first. Then I would get some rubbing alcohol to see if a small area cleans up. If it does not clean up then I would break out the polishing machine starting with a mild abrasive polish. Hopefully the stains are not through the clear coat.
Ok... Before you do anything damaging ... Face the car into the hot sun for a couple hours/days. I have seen this before. The clear will actually take on moisture and do this. The other alternate is a hair dryer but watch you dont thermal shock the paint.
eriddler (07-16-2013)
Interesting, I will try this today now that we might actually have sun vice rain in AL....I'll let you know.
2016 E350 Sport
Oakes
Wash & Wax
10-12-2015 11:17 AM
