Paint Chip on Hood!
Paint Chip on Hood!
So what should i do?
Should i touch it up with the touch up paint?
anybody know about Langka. or Mother's paint repair?
i have 2 very small chips and a small scratch...
all of them are into the metal.......
sorry ..no pics....
any suggestions would be very mych appreciated....thanks
And i'm not gonna repaint it............
sorry ..no pics....
Not a Blowhole
Suggest a search - this has been treated in detail many times. I will say that I have never been able to get the Langka to work right - and my questions to Mothers were never answered, so i will never buy anything from them again. CS stinks.
I found the DGB Honda paint was an excellent match - I use a toothpick or a paper match cut to a Vee for spot T/U's.
Boy Genius
Tried Langka here too, but it was tough to get to work right, especially on WDP. The only way to really do it right is to apply the paint carefully using a toothpick, fine brush, or whatever, and to then sand down and polish. Not sure how noticeable the chips are or if you get a lot of salt or other elements, but always a good idea to patch up if you can, especially if it's down to the metal. You might need primer between the metal and the paint. Good luck!
Spinnin them beats
yea, the clear bra id a great way 2 protect the front end unless the scratch is higer than that..... i only use touch up when the scratch appears white on dark colored cars or vise virsa... if u hav to use touch up paint, i suggest cheaning it really good while not using wax. then apply the paint and use wax after it dried.. i used it on our toyo land crusier which had a matallic color and worked ok. one more thing, what color is ur car? if its matallic, be sure 2 shake the touch up paint ALOT!!! if u dont, the pain will hav no sparkles and wont match the car
they are very very small scratch and chips....
i just want to know how to apply the touch up paint smoothly to blend into the hood.
one of them is a hair-line scratch about 3 milimeters, and the other 2 are like small points caused by something sharp like a needle. its like how a compass would create a small hole in a peice of paper...
i'm a newbie at touch up paints.
Boy Genius
Originally Posted by chewi
my TL-S A-spec is a Aegena Blue...
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
