Oops
Old Oct 21, 2010 | 04:48 PM
CocheseUGA's Avatar
Oops
I was very impatient today, and I am paying for it. It's been quite a long time since the car had a proper wash, and I had time today so I went for it. That went fine. Then I found I had a bit more time, so I went for a clay. Then I thought I could cut a couple of corners and put a quick polish on. Used HC II on a orange pad without bothering to take care of the clay residue. I think I used quite a bit too much polish as well.
The end result is I have a lot of haze and holograms. How do I remove these? I was thinking that I need to strip all the polish off with the proper dilution of CCWG and start over. Yes?
Old Oct 21, 2010 | 05:28 PM
vinnier6's Avatar
you cant strip polish off of a car, just like you cant put a polish on a car, polish is something you do to cars finish, and it sounds like you didnt do a good job of that or take your time....
just start over again, and take your time...think of polish as a sand paper or as the process of sanding wood...
