NXT vs. Turtle Wax
NXT vs. Turtle Wax
The the NXT tech stuff really that much better? It's 6 times more expensive then the turtle wax. In Canada, the NXT tech sells for $30 while the Turtle wax only goes for $5 a bottle.
Also, what's the difference between the paste and the liquid? What's better?
All go, no show
I thought NXT only came in liquid form?
Anyway, there's no difference b/w paste & liquid forms of wax. I used to use turtle wax back in the day, but I use NXT now. In my opinion, it's a lot easier to apply (partly because it's liquid and it's easy to measure out exactly how much you want to apply) and easier to take off. It also lasts longer and has a bit of polish in it.
I'm guessing most people are going to say screw turtle wax and stick w/ NXT. Really though, try both of them out. If you don't think it's worth the extra $, then stick to the cheaper stuff... it's not going to hurt your car!
Needs more Lemon Pledge
Do half your car in each and decide which you like better.
Penquin, NXT now comes in a paste. No difference betwen them. As far as which product is better - you have to decide for yourself. If you like the results of one over the other, ...... Just remember, you need to prepare the surface of the vehicle i.e. remove contaminents and swirls, otherwise it's all for nothing.
I need 2 more gears
NXT is a glaze, it's a polymer based sealant. Glazes last anywhere from 4-12months under normal conditions, while carnuba's last a few weeks. If you get a good carnuba wax like Klasse, Zaino or Pinnacle and top it off with two layers of glaze that will make all the difference. I agree prep the surface or the finish will suffer. Rule of thumb is wash, clay, polish, carnuba, carnuba, glaze, glaze, perfect! NXT is a much higher grade glaze than turtlewax and will produce better results. Plus its easier to use and smells great too!
Originally Posted by nitehawktsx67
ive got nxt in paste and man is it good stuff!! whats a good polish and carnuba and claybar to use?
Former Sponsor
My rule of thumb: (Prep shows Pride)
Wash
Clay
Polish (This includes SMR, and/or cleaning)
Glaze (If necessary, desired)
Seal
Wax (If desired)
9.5+10.5 22m=Hella Flush
NXT is a great product as it makes the car paint very shiny and wet looking. However the only draw back is it is very expensive compare to other brands and after 4-5 car washes it seems that you need to wax the car again. So it does not last for a very long time like some other wax brands.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
expensive? It's $14 a bottle and a bottle will do a good 30 waxes
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
You'd die when I tell you I have products that are almost $100 a bottle
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Originally Posted by CLpower
expensive? It's $14 a bottle and a bottle will do a good 30 waxes ![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
You'd die when I tell you I have products that are almost $100 a bottle![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
It may be $14 a bottle where you live but up here in Canada is $30 cdn a bottle which works out to be around $26 a bottle. It is expensive in terms of comparing other brand Waxes.
Originally Posted by jlukja
Does claybar remove the NXT wax? I waxed with NXT this past weekend. If I claybar next weekend will I need to do another coat of NXT after claybar?
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
