I bought this Nu Finish Scratch Doctor stuff to use on a scratch. What exactly are the directions in detail on how to use it?
Let us know how it does work, Ive been meaning to try it...
As for directions, shouldnt they be on the back?
They just say apply a small amount and leave on until it gets hazy. WTH is hazy (i know what hazy is but still, the product come out of the tube hazy to begin with)! I just rubbed that stuff on hard and im leaving it on for an hour. 9 more minutes and ill take it off. hope it worked =)
Let me know how this works for you. It would be great if someone had b4 and after pics. Once I hear about what has worked the best than I will attempt in mine, as well as post b4 and after pics!
Former Sponsor
Its really nothing more then a compound........be careful with all compounds......Its not going to do anything after you rub it in......Just wipe away after applying.....
2016 E350 Sport
If the only thing you do is wipe on and wipe off then its only a filler. Your scratch will still be there. In order to remove any scratch or swirl you have to remove some paint/clearcoat. This means you need an abrasive product that has to be worked into the paint by hand or by machine. Proper technique will determine whether you make the surface worse or remove the scratch entirely.
