New @ exceldetail.com 303 Carpet/Upholstery cleaner
Former Sponsor
![](http://i14.photobucket.com/albums/a304/exceldetail/303/cleanspot275.jpg)
303 Cleaner & Spot Remover 32oz
303 Cleaner & Spot Remover utilizes a proprietary blend of sequester agents, surfactants and hyper-wetting agents to lift and suspend oil, grease and dirt to be easily wiped/rinsed away. It is extremely safe and may be used on all water-safe fabrics and surfaces. The cleaning action increases with warm water, agitation and a longer dwell time.
For $8.99?
Does it get any easier?
DIRECTIONS:
Normal Cleaning: Spray on 303 Cleaner & Spot Remover until damp. Completely wipe away dirt/grime with damp cloth until clean, rinsing out cloth as required. Allow to dry completely before use.
Heavier Cleaning:
Spray on 303 Cleaner & Spot Remover until wet. Agitate with wet, medium-soft brush or wet cloth. Let stand. Then wipe away dirt/grime as described above. Dry completely before use.
Machine Extraction:
Add 4-8 oz of 303 Cleaner & Spot Remover to 1 gallon of warm water.
Spots:
Fresh Spills: Use a clean absorbent cloth to blot up as much of the spill as possible. Adjust sprayer nozzle to appropriate size and spray 303 Cleaner & Spot remover on the stain until stain starts to diminish and blot up with clean absorbent cloth. Rinse with water to remove excess cleaner. Dry completely before use.
Spots / Stains:
Spray the spot until wet with 303 Cleaner & Spot Remover.Agitate with wet medium-soft brush or wet cloth and let stand. Then blot up the stain and excess cleaner as described above. If necessary, repeat, agitate and let stand a few minutes before wiping clean. Dry completely before use.
will this stuff work on grease stains that have been on the carpet for more than 2 years? I have some nasty stains in the TL from the previous owner and have been kinda scared to use a product that will bleach out the carpets.
Will this product work to clean salt from the carpet? I need a reliable product to clean my carpets after the winter.
Former Sponsor
The best thing with salt is extraction. The 303 will help neutralize it, bit extraction works well. Even with a wet vac, its better then without.....
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
