need help removing bugs and other stuff off front bumper!
Future JDM Whore
i need to know what i can use to get the bugs and shit off of my front bumper.....also i have a little bit of epoxy glue on the front bumper from when i was putting on the eyelids the wind blew and some got on the bumper anyone know what products i can use to remove these things???
All Hail the Chief
I wouldn't recommend anything abrasive.
Just use a soft wash mitt and regular auto wash soap and apply a little elbow grease! This will work on bugs that have been sitting a while too.
The easiest way is preventive maintenance. Keep your front end waxed often during the spring/summer months and you'll notice how easy it is to remove the bugs.
As for the glue, I wouldn't know.
You could also try to "clay bar" the front end. That should also clear up a lot of the bugs. Since even after washing it with a little elbow grease. It's still possible that the surface isn't completely smooth.
So... claybar... then polish... and wax. If you keep a good coat of wax on there. In the future, bugs wont stick as easily.
I like Turtle Wax Bug and Tar. It's a thick liquid that stays where you spray it. Let it soak than wipe off. Best of all, it leaves a wax finish. I use it on my clear bra as well with great success!
Forget the clay bar unless you plan to throw it away afterward. Use elbow grease and if that doesn't work use WD-40 and let it soak on there a few. As for the glue, you could try some rubbing alcohol.
Slats
Slats
You know what works that makes your problem easier? more wax
My uncle had a Vette and he always put like 3-4 layers of wax of the whole front bumper area whenever he was detailin it. The area is so smooth and techincally the bugs dont touch or have anything to cling to your car. I swear to u, all u pretty much had to do was wipe your finger across the bumper and almost all the bugs smeared off.
Makes it so much easier come bug cleanin time.
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
