Navigation Screen?
Navigation Screen?
What is the best way to clean the fingerprints off the navigation screen? I'm scared to use anything but a cloth at this point, but hoped that someone on this forum would have some insight. Thanks.
I've actually found that the my cleaner and cloth for my oakley sunglasses does a great job! I figured if it doesn't scratch sunglass lenses, it should be safe on the navi-screen..I was right and that's what I use now. You can get a sunglass cleaning kit with the special cloth and spray solution at Sunglass Hut for about $10
Your Nav screen is basically the same as a laptop or LCD screen. Here are a few SAFE methods and recommendations:
1. Use clean water and a microfiber lens cloth. Just dampen the cloth slightly and use a dry cloth to wipe down. Usually a dry micofiber lens cloth is all it takes.
2. for the really tough dirt buy cleaner designed specifically for laptop or LCD screens:
- iKlear Klear Screen (recommended by Apple and ViewSonic)
http://www.klearscreen.com/index.html
3. ...or make your own cleaner
- 50/50 isopropyl/water mix
- Water with a little vinegar in it
(the difference is the commercial products usually contain dust and static inhibitors)
4. DO NOT USE WINDEX or other glass cleaners
- they contain amonia and/or alcohol
- they can yellow the screen
- they can make the screen brittle
- the screen is plastic not glass!
dirleton
Aug 6, 2024 08:19 PM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
