Meguiars #80 & #83
Old Sep 23, 2006 | 02:05 PM
italian_spak's Avatar
Meguiars #80 & #83
i wanna know which product is more effective to remove swirls and remove contaminants in the paint like those deep incrusted water spots in the paint.
thanks
Old Sep 23, 2006 | 09:14 PM
Vicman17's Avatar
thanks
83 seems to be more effective but a bit trickier to remove.
Old Sep 23, 2006 | 11:39 PM
SweetJazz's Avatar
2016 E350 Sport
Both products will remove swirls. I recommend using the least abraisive product first and then evaluate the results. Start with a 1-2 square foot test area. Note that #80 is a cleaner/polish that contains polishing oils while the #83 is more of a pure cleaner. However, you may put on a wax right after the #83 with good results. The test spot is key! It can prevent you from completing your car only to find that the results are not what you wanted. If you are using a PC then these two products can be the foundation of your car care system.
Water spots can be very tricky. You may try some dilute vinegar on a test spot to see if the spots dissolve.
Old Sep 25, 2006 | 11:40 AM
re
ill get #83 since im sealing my paint and adding final wax, how much should i diluate the vineagar? 50%???
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
NSXNEXT
Wash & Wax
Apr 15, 2005 06:46 AM
CLpower
Wash & Wax
Sep 6, 2004 09:44 AM
Amoeba
Wash & Wax
Nov 5, 2003 11:08 AM
